Painting spark plug cover?
Old 04-26-2001, 08:22 PM
Ravq's Avatar
I plan on painting the fascia that covers the spark plugs not the valve cover but the piece with "Nissan" written on it and would like to know what kind of paint you guys that have painted them used? Hi-temp? I'm looking for something really glossy. Any advice greatly appreciated.
Ravq is offline
Old 04-26-2001, 08:23 PM
Sprint's Avatar
People have used hi Temp engine paint.. and then Clear coate after..
you can use tape to cover the nissan letters..
Sprint is offline
Old 04-26-2001, 08:27 PM
Ravq's Avatar
Any prepping required besides cleaning it? Do I need to sand or primer it?
Ravq is offline
Old 04-26-2001, 08:40 PM
Sprint's Avatar
not sure.. jeff k did it.. you can ask him..
Sprint is offline
Old 04-26-2001, 08:56 PM
Master Will
metallic97gxe's Avatar
I just cleaned mine real good then painted and I did not use high temp paint....just clean it and let it dry tape what you don't want to paint and spray many light coats and you should be fine
metallic97gxe is offline
Old 04-26-2001, 11:25 PM
Justin95SE's Avatar
thats exactly what i did
i used a high temp engine paint.. oh yah, first i super duper cleaned it with B12, carb cleaner, works really good. then i clear coated it a few times. 6 mos and only one small scratch too.
Justin95SE is offline
Old 04-27-2001, 06:02 AM
sinewave's Avatar
Wet sanding the cover with 600 wet-n-dry sandpaper in a sanding block will give you a much better final result.
sinewave is offline
Old 04-27-2001, 06:30 AM
Sprint's Avatar
have i told you that your engine bay is sexy?
Sprint is offline
Old 04-27-2001, 07:45 AM
i SeE what you did therE
redmaxpa007's Avatar
A little trick for covering the "NISSAN" on the spark plug cover.
put some grease on the top of the raised letters.... spray paint all you want... and when you finish spray painting and you can just wipe/peel off the grease and boomm...
lookin good..
my 2 cents
redmaxpa007 is offline
Old 04-27-2001, 09:01 AM
sinewave's Avatar
Thanks SprintMax, I try to keep it clean.
I don't think I would try the grease trick. It takes so little in the wrong place to ruin a paint job. I used masking tape and spent an hour with an Exacto knife to trim it out. Someone a year or so ago said that they bought some liquid masking stuff at Home Depot. I never tried it, so I can't recommend it.
sinewave is offline
Old 04-27-2001, 09:04 AM
the grease took 2 minutes. use a little bit on your finger.. the letters are raised... it is kinda hard to mess it up...
Old 04-27-2001, 12:31 PM
Maxima.org Sponsor and Donating Maxima.org Member
dmbmaxima2k2's Avatar
I DID IT
I did mine yesterday when i was painting the hub part of my rotors, you can see them with my new rims. I just taped off the black nissan center part and painted the NISSAN raised letter. I used the brake cleaner i had to clean it and it took the paint real good. I used high temp engine enamel and three coats of high temp clear coat. It looks mint.
dmbmaxima2k2 is offline
Old 04-27-2001, 01:08 PM
nismomaxse97's Avatar
Damn and hour, you are a definite entheusiast.
YOu can also use finger nail polish to paint it and then after painting just chip or rub it off with remover and cotton ball.
nismomaxse97 is offline
Old 04-27-2001, 05:49 PM
Ravq's Avatar
Thanks for all the suggestions guys I'm gonna try to tackle it on my next day off.
Ravq is offline
mvm062
11-30-2020 09:00 AM
homewrecker
09-23-2015 03:41 AM
JoshG
51
09-21-2015 10:41 PM
zzznightmarezz
09-21-2015 06:32 PM
cruce91
09-20-2015 10:23 AM
Quick Reply: Painting spark plug cover?
