Time for new spark plugs
Old Jan 27, 2005 | 09:12 AM
gto400no1's Avatar
Well i think it is time to get new spark plugs, im at 114k and i dont know the last time they were changed and i only get about 16 mpg in the winter and like 18.5 in the summer. where should i go to get the ngk coper plug? i have pep boys, napa, advanced auto parts, and autozone near me, wut one of them have them? how much do they run?
Old Jan 27, 2005 | 09:40 AM
flthere's Avatar
Maybe at the dealer for $1.99 per plug ...
Old Jan 27, 2005 | 09:49 AM
ajcool2's Avatar
Any reason you getting copper?
Old Jan 27, 2005 | 10:04 AM
DAVE Sz's Avatar
Hooooooonda.....
yeah, they smell like candy
Old Jan 27, 2005 | 10:11 AM
jbreit's Avatar
NAPA for the coppers. Or, go tot eh dealer and tell them you have a 94 maxima
bkr5egp from clubplug.net are like $3.50
Old Jan 27, 2005 | 10:48 AM
I30tMikeD's Avatar
Dealer, Napa, pepbays...they are all within 25 cents of each other, just go the the closer place. BKR5E-11 is the PN for the coppers....or it might be BRK5E-11. I can never remeber which one, but only one is a real PN so it does not matter.
Old Jan 27, 2005 | 11:54 AM
alpicone's Avatar
Is there any dif between the coppers and platinums as far as performance? I know that platinums will last longer but it is a big price differnece between the coppers and platinums, so if the coppers are fine I would go with them. Changing the plugs is easy and takes less than 20 min.
Old Jan 27, 2005 | 12:03 PM
ajcool2's Avatar
I dont know that much about the diferences between the two but i can tell you i just replaced my sparkplugs and put in bosch platinum 4's and i felt a big difference in performance and gas milage.
Old Jan 27, 2005 | 12:24 PM
hacim105's Avatar
No you didn't it's all in your head. Because if you use anything other than NGK you car will not perform at it's best.
There is a thread that explains it all.
I believe the coppers give a little better spark than the platinums. The platinums cost $60-$70 for six the coppers cost $12-$18. The platinums last 60k, coppers last 30k. So even if you go with the coppers you change them twice in the time of a plat. but you will still save anywhere from $24-$36.
If you're really looking to get the most out of your car, NGK has other spark plugs. I believe there is the:
Standard - Copper
V-power - Copper <--- this is what you WANT from the dealer
Platinum - Platinum <--- this is what the dealership will recommended you
G-power - Platinum
Iridium - Iridium
Iridium Extreme - Iridium
I don't know where to get the other kinds of plugs. I imagine you would look for a NGK dealer.
Old Jan 27, 2005 | 02:31 PM
wayman's Avatar
I just bought a set of copper NGK's for rmy 98 GXE from Autozone and the total was about $14.
BTW, gap for coppers is 0.044. No gap for platinums, plug and play.
Old Jan 27, 2005 | 03:37 PM
Zeus97MAX's Avatar
I just bought NGK plats off of sparkplugs.com for a total of 17 bucks, shipped to the front door. I have a 97 and just turned 60k miles today, so tomorrow I will finish up all of my 60k maintenance with some new plugs. As far as I know, also, the NGK plats don't need to be gapped either.
Old Jan 27, 2005 | 03:41 PM
maX5's Avatar
which spark plugs will make a difference on performance and fuel econmy ?
Old Jan 27, 2005 | 08:36 PM
PLUMMAXSE's Avatar
Should get better throttle response from the coppers and fuel economy will be the same on both types of plugs. I had the platinums in for 30k and then switched to BKR5E-11's. Copper V-plugs or Stock # 6953 at pep boys for $1.79 ea. I'll switch them every 30k and drive hard!!
Old Jan 27, 2005 | 10:09 PM
DAVE Sz's Avatar
Hooooooonda.....
BS. The 11 at the end of the number is what the plug is pre-gapped to. Both coppers and plats have it. Either one you get make sure to gap them yourself, unless you're the biggest idiot there is of course, if that's the case just put them in straight from the box without gapping. If you have half a brain though, check the gap of every plug you ever put in any car. BTW, the gap is .039"-.044".
Old Jan 28, 2005 | 05:38 AM
flthere's Avatar
DId u mean each plug for $17 !?! If it's total, then something is fishy ...
Old Jan 28, 2005 | 07:37 AM
96ItaliaSE's Avatar
il massimi bassi
the ones on sparkplugs.com are coppers so makes sense
Old Jan 28, 2005 | 08:15 AM
flthere's Avatar
no .. there is another platinum GP plugs each around $2.74 or sthg in the site ... maybe he got them ...
Old Jan 28, 2005 | 08:50 AM
illmortal's Avatar
Actually when I went to the Dealership after reading this thread they recommended Iridiums because I have over 150k miles on my I30... I think he was just trying to scam me... cuz they cost $6.78 each. Then I mentioned the V-Power Copper and he said that it would give me poor gas milage... I dont like this dealership that's twice I was lied to >< (1st one was over the I30 not being able to have a rear sway bar)
Old Jan 28, 2005 | 09:03 AM
s0ber's Avatar
I found mine at Discount, for NGK Coppers.
Old Jan 28, 2005 | 09:57 AM
hacim105's Avatar
I finally found the information on the part number of the plugs and Dave Sz was right the number 11 is what the plug is pre-gapped to which is 1.1mm or in inches terms .044" which is why the nissan dealership orders them with the 11 gap size. Just letting you know if you order them you DON'T need to gap the plugs unless there has been damage done but you can always double check them. This is for NGK plugs:
Old Jan 28, 2005 | 10:36 AM
Zeus97MAX's Avatar
Flthere, yea it was about 17 bucks total. the plugs are 2.68 each, not including shipping. The part number is BKR5EGP.
Old Jan 28, 2005 | 11:38 AM
BlueC's Avatar
wat
Spent $10 total from NAPA for all 6 copper plugs. That was with the antiseize grease packet I bought with it. I also have a discounted account on file there...
Old Jan 28, 2005 | 05:00 PM
DAVE Sz's Avatar
Hooooooonda.....
They were scamming you. Iridiums are pointless on N/A cars, they are a waste of $$$. From what I read iridiums works well on boosted cars.
Old Jan 28, 2005 | 05:20 PM
Ant96GLE's Avatar
The actual part # its stocked in is NGK 6953
They are V power plugs, I just asked for 6 plugs for a 97 Altima... they use those plugs.
Platinum plugs are coated with a sheet of platinum to help them last longer, thats about it.
Old Jan 28, 2005 | 06:19 PM
karguy's Avatar
NGK platinums are going for $28.00 plus $5.00 shipping on eBay. Part number is PFR5G-11. Go with the Platinums and forget for 60,000 miles
lowpost99
22
Sep 2, 2015 04:38 PM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
