Everyone with a CF hood...POST PICS.
Old Feb 2, 2005 | 12:46 PM
  #41
DR-Max's Avatar
The latch and the cables are that heavy??? I'd say the latch is about 1lb, cables another lb or two. My sister's puppy is heavier than that!
Originally Posted by Broaner
When I get a CF hood I plan on getting key locking pins. That way I can get rid of the OEM latch and cable to save weight and clean things up.
Old Feb 2, 2005 | 12:52 PM
  #42
Flava_24/7's Avatar
Boosted Panda
When you get the locking hoodpins, post pic of them installed. Id like to see how you get them to fit.
Thats the route I wanted to go with but couldnt get them to line up to lock.
Old Feb 2, 2005 | 01:01 PM
  #43
Kta920's Avatar
How are these hood hydraulics supposta come off?! need help quick
Old Feb 2, 2005 | 01:27 PM
  #44
Broaner's Avatar
2060lbs and falling...
Look at page 11 of my homepage and you'll understand. 3lbs is a lot in my book.
KTA, stick a screw driver in the clip on each end. Pull away from the stut and then pull the strut out. The clip is springy and holds onto the ball joint. You'll have to get it that way on the hood but if you can't get it on the bottom you can just unbolt it.
Old Feb 2, 2005 | 01:29 PM
  #45
1MAX2NV's Avatar
Small open end wrench. I think like 10mm or smaller. You will see it at the base of the support. It helps to have 2 or more people helping. The hood support could extend out and scratch your paint if you are not careful.
Old Feb 2, 2005 | 01:32 PM
  #46
Kta920's Avatar
thanks guys.
Old Feb 2, 2005 | 01:34 PM
  #47
DR-Max's Avatar
I know what your project is. I was joshing you! Now if you can manage to sit in your car and not add an ounce of additional body weight in it, then that's one hell of an accomplishment.
Old Feb 2, 2005 | 08:23 PM
  #48
Magikone69's Avatar
i kno nothing about pins, anyone have any special recomendations, or brands i should steer clear from.
i see some hayame gunmetal colored ones. i think ill get these and call it a day. 9 bux + ship
Old Feb 3, 2005 | 12:06 AM
  #49
Oblongshapes's Avatar
Sorry, a lil dirty
Old Feb 3, 2005 | 12:54 AM
  #50
jcy98maxse's Avatar
Turbo is too much fun!
what company are you guys getting your hoods from?
Old Feb 3, 2005 | 09:17 AM
  #51
Kta920's Avatar
i just bought the moroso hairpin hood pins from SummitRacing.com
Old Feb 3, 2005 | 09:35 AM
  #52
Broaner's Avatar
That would certainly be an accomplishment. Invent that device and you'd be a millionaire. LOL.
Old Feb 3, 2005 | 12:37 PM
  #53
Ant96GLE's Avatar
Paradox systems carbon fiber hood
Old Feb 3, 2005 | 11:53 PM
  #54
Custom carbons...
ant96gle, what springs are you dropped on man?
Old Feb 4, 2005 | 06:56 AM
  #55
Shadow's Avatar
Wife's Integra with Sparco pins
[IMG]Integra
My car with cheap Autozone pins (got the hood from Sadler and it was already drilled for that size pin so I couldn't use Sparcos.)
Maxima
Old Feb 4, 2005 | 10:28 AM
  #56
Broaner's Avatar
Please god link those pics. They done fxcked this thread up. Your car looks fantastic Shadow. I'm interested having some similar paint work done on my trunklid. How do they get a clean line at the edge of the letter like that? Every time I've seen it done like that it needs a pinstripe to hide where the paint crept under the tape.
Old Feb 4, 2005 | 10:35 AM
  #57
DR-Max's Avatar
Shadow, those cars are awesome. Question, is the hood on the integra cf? So does it mean that you can paint over a CF hood? This whole concept is pretty new to me and the only reason why I'm considering CF hoods is because the hood that's on my car is all messed up and I wanted to get a nicer hood so I figured why not get a CF hood and at the same time reduce some weight from the car. Is the process the same when painting a CF hood? Thanks.
Old Feb 4, 2005 | 10:38 AM
  #58
Flava_24/7's Avatar
Boosted Panda
They normally just put down vinyl and shoot on top of it.
I agree, Shadows car is nice!
Old Feb 4, 2005 | 10:41 AM
  #59
TJ_Max's Avatar
Paradox Systems Vendor
im sorry did u just say ure wife's? integra?
Old Feb 4, 2005 | 10:57 AM
  #60
DR-Max's Avatar
So would it give off the same look as when you paint fiberglass? Which in that case, the paint matching is a little off because of how glass looks painted versus metal.
  #61
Shadow's Avatar
The lines were taped, the letters were paint mask vinyl. I just cut the logos out at my shop and my friend who runs a body shop took care of the rest. I'm not sure why it would bleed through the tape unless it was done wrong.
Old Feb 4, 2005 | 10:58 AM
  #62
Shadow's Avatar
The hoods on both cars are CF. And both are painted, it's just harder to tell on mine because the color is darker. No reason you can't paint CF.
Old Feb 4, 2005 | 10:59 AM
  #63
Shadow's Avatar
Yeah, it's the wife's car. Her daily driver actually.
Old Feb 4, 2005 | 11:03 AM
  #64
euromaxima's Avatar
Can't wait to see how my hood will turn out, will post pics when I get it done.
Old Feb 4, 2005 | 11:07 AM
  #65
Shadow's Avatar
The vinyl is just a mask, it's peeled before they spray clear, like a stencil.
Why would fiberglass look different than metal painted? Both the cars have fiberglass bumpers and the paint matching is perfect. On the Integra, the kit is even molded in sides and back along with the wing, no shade variation at all.
Old Feb 4, 2005 | 11:14 AM
  #66
DR-Max's Avatar
I was just wondering because my buddy builds pre-runner (offroad) trucks and they use fiberglass fenders. His is white and the white fenders just don't match up right. I figured it would be the same for cars.
Again, excuse my ignorance here, but the CF is just a layer that's ontop, the hood is entirely made out of fiberglass right? If that is the case, I can probably have someone that makes a CF hood, just make me a plain fiberglass hood and I'll take it to the body shop for painting.
Old Feb 4, 2005 | 11:19 AM
  #67
Shadow's Avatar
If everything is primed and sprayed properly, it should match.
As for the CF hoods, they vary between all CF and 1 layer of CF on top of fiberglass (cheaper hoods). On my Fiber Images Hood, it's all CF with a fiberglass frame. On the wife's, it's a double sided hood (CF on the underside too) which is a few layers of carbon sandwiched on fiberglass.
Old Feb 4, 2005 | 11:23 AM
  #68
DR-Max's Avatar
Ok...obviously, I'm trying to save myself some money and I really don't want CF showing because it would just throw off everything else in my nearly stock exterior. With that, I'd be waisting money on a hood with any kind of CF treatment since it's only going to be covered up in paint. So in my situation, what would you recommend?
Old Feb 4, 2005 | 11:24 AM
  #69
euromaxima's Avatar
[/Quote]Again, excuse my ignorance here, but the CF is just a layer that's ontop, the hood is entirely made out of fiberglass right? If that is the case, I can probably have someone that makes a CF hood, just make me a plain fiberglass hood and I'll take it to the body shop for painting.[/QUOTE]
Why not buy a carbonfiber hood and just paint it, it would be no different than making one out of fiberglass. a fiberglass or carbonfiber is about the same price
Old Feb 4, 2005 | 11:38 AM
  #70
DR-Max's Avatar
Got it, thanks.
Why not buy a carbonfiber hood and just paint it, it would be no different than making one out of fiberglass. a fiberglass or carbonfiber is about the same price[/QUOTE]
Old Feb 4, 2005 | 11:16 PM
  #71
Broaner's Avatar
Only the really sh!tty ones have the carbon just laid over the glass. My trunk is a glass frame with carbon exterior surface. I can see intense and direct light through the bottom of mine. This isn't necessarily a good thing but it proves that its not an overlay.
halfpol
Oct 17, 2022 12:16 PM
Apr 16, 2020 05:15 AM
t6378tp
Sep 29, 2018 04:27 PM
timmay5835
Sep 15, 2015 06:09 PM
neilraz
Sep 11, 2015 07:36 PM
