Alarm Beep
Old Feb 15, 2005 | 12:12 PM
SDB318's Avatar
Alarm Beep
Just wondering if anybody has done the Alarm Beep Mod. i wanted to know how it sounds and how hard it was to do. i already have the buzzer and the relay.
thanks
scott
Old Feb 15, 2005 | 12:25 PM
maxtuner96's Avatar
thanks
scott
I did the alarm mod on my car a few month ago. I'm really happy with it. The install was easy....don't follow the instructions on the writeup though...the relay is useless. Just splice into the positive and negative wires in the trunk (I forgot wich ones they were, but they were pointed out in the writeup). Also, try to get the buzzer to sit outside the trunk (under the bumper) so you could hear it better. I ran the wire through a hole behind the bumper that lead into the trunk.
Old Feb 15, 2005 | 01:17 PM
cam_honestiam's Avatar
I did a complete write-up for this because the other write-up mentioned some unnecessary things (as mentioned by maxtuner96).
The mod is great, cheap, and a bonus for people who don't like to sit and watch their lights flash. In my write-up, I included instructions for installing not only a rear but also a front buzzer. Sorry I don't have a .wav file, but don't worry about what it sounds like. Get the buzzer you like (test it while at the store if possible) and make sure it has plenty of volume so you don't have to be within 5 feet to hear it.
Old Feb 15, 2005 | 01:25 PM
SDB318's Avatar
can radio shack test them for me but i alright have the one that is said to use in the how tos on vqpower.com
Old Feb 15, 2005 | 01:35 PM
Radio Shack should let you listen to it, depending on the sales guy. If I were you, I would try to listen to a couple. You can even buy several, connect them to a 9V battery (one at a time) and listen. Take back the ones you don't want (just be sure to be nice to the package so Radio Shack will take it back).
Old Feb 15, 2005 | 01:37 PM
SDB318's Avatar
what one did u get
Old Feb 15, 2005 | 03:36 PM
DRIFFT MAX
somebody post a pic with the correct wires cuz i tried it and failed because i couldnt find the right wires.
Old Feb 15, 2005 | 05:35 PM
MAXRB8's Avatar
Sooooo......... how about posting that write up? thanks
Old Feb 15, 2005 | 05:43 PM
tedo007's Avatar
faster than you think
i didnt use relay. it works fine for me. i love the sound.
Old Feb 15, 2005 | 06:06 PM
SDB318's Avatar
what does the relay really do then
Old Feb 15, 2005 | 06:09 PM
Igobuk's Avatar
The relay was intended to not overload the stock circuit but the way it's wired, the circuit ends up powering the relay AND the buzzer, actually stressing the stock circuit more than without the relay.
The buzzer (actually a beeper) can be wired in without the relay, it won't affect the stock circuit at all.
Old Feb 15, 2005 | 06:21 PM
SDB318's Avatar
where does it go
Old Feb 15, 2005 | 06:38 PM
Igobuk's Avatar
where does it go
Wire in the beeper where the relay would have been wired in. The G/OR wire goes to the 12+ of the beeper and the OR wire goes to the ground wire of the beeper.
Old Feb 15, 2005 | 08:03 PM
DRIFFT MAX
wow if that is special ed certified then what is
Old Feb 15, 2005 | 08:12 PM
big_al's Avatar
ya, make sure you get one loud enough. Its hard to here mine in noisy areas or on windy days.
Old Feb 16, 2005 | 06:57 AM
SDB318's Avatar
then just replace it
Old Feb 16, 2005 | 07:06 AM
ny96max's Avatar
see if you use a relay it will allow you to really hook up any type of buzzer small or larger and or a basic alarm siren too. Its only gonna be an extra 3 wires to hookup a relay. Id also recommend using a 5-10amp inline fuse on the main line thats in the trunk coming from the stock security system.
Ant
Old Feb 16, 2005 | 08:08 AM
tedo007's Avatar
well it beeps two times so you dont reallly need relay thats what i think
Old Feb 16, 2005 | 11:15 AM
SDB318's Avatar
so without the realy i would just have to slice into the two wires it says to. not also it says to remove some fuses i beleive
Old Feb 16, 2005 | 01:02 PM
I will post my write-up again as soon as I can. It's been on here several times alreday...
Old Feb 17, 2005 | 07:47 PM
SDB318's Avatar
so how bout that write up
Old Jun 21, 2005 | 01:32 PM
MAXRB8's Avatar
I hooked up a siren to mine connected the Positive to the orange/green stripe wire to one ( there's 3) closest to the solid orange, the solid orange runs to the BCM ground wire from the siren taps into this, no relay. Works great. The plug connection is as the Vqpower writeup. Easy mod, cheap too. I really like being able to arm the car and not always looking back at the lights to make sure it's armed.
Old Jun 21, 2005 | 01:37 PM
ManualMaxima's Avatar
5th Gen till she dies!
i used the buzzer for ahwile and to me it sounds like an 80's car alarm.......i went and bought a back-up beeper for an auto store, and now it sounds like when a bmw locks.....much better.
do it the way that everyone has been saying. I did it the way using the relay and it was kinda confusing but it got done.
Old Jun 21, 2005 | 03:55 PM
sparkyssb's Avatar
i used the 12v siren sounding one from radio shack.
http://www.radioshack.com/product.as...t%5Fid=273-079
it goes, wee wee....wee wee
i like it...the people at work says its the 'french sounding alarm'. lol
Old Jun 21, 2005 | 04:04 PM
MAXRB8's Avatar
Err wouldn't that be Oui Oui..... Oui Oui?
Old Jun 21, 2005 | 04:36 PM
sparkyssb's Avatar
lol um, no...it makes a wee wee sound
Old Jun 23, 2005 | 04:45 PM
99-max-ster's Avatar
is it possible to just use a horn from a max in the junk or something similar to it?
Old Jun 23, 2005 | 05:50 PM
86maxima96's Avatar
I Broke OT
where is the best place to get these beepers? someone mentioned one sounding like a BMW. could you just go to the junkyard and yank one outta any car as long as it's a two wire hook-up, or what? (i am by no means electrically inclined)
Old Jun 23, 2005 | 05:57 PM
Black Maxima
So it's not possible to hook it up to your stock horns?
Old Jun 23, 2005 | 06:15 PM
ryant35's Avatar
I have a much better diagram for this install but I can't post attachments, if someone wants to email me at rtorres53@hotmail.com I will forward the diagram if you will post it in this forum.
Old Jun 24, 2005 | 07:24 AM
sparkyssb's Avatar
Incorrect. Anything is possible. I just drew this up for you...I haven't used it but I'm sure it will work.
Take care.
Old Jun 24, 2005 | 09:40 AM
Black Maxima
Oh thanks! That would be phat. Could you be more specific with the directions on how to do it. Like where I can find the multi-remote control relay?
Aaron
Old Jun 24, 2005 | 11:12 AM
sparkyssb's Avatar
sure. the remote control relay is in the back of the car, located near the assembly for the trunk latch. It is an orangish relay. You will find the green/orange wire I noted in the above diagram connecting to it. Tap into this wire and wire it to the SPDT relay on pin 85. As for the rest of the relay, ground out pins 86 and 30. Run a wire from pin 87 to the horn wire (should be green/white under the steering column). If it were me, I would normally include a 1 amp diode inline so feeback from using the horn or the car alarm wont go back into my circuit. However, it is not necessary with this particular setup because it runs back to a switch and cannot go anywhere.
To recap the pin connections:
86 - Ground
30 - Ground
85 - Green/Orange wire in the trunk (remote control relay)
87 - Green/White wire under the steering column (horn)
You can also use a SPST Relay for this application. It only has the pins you need and not the extra 87A. It might be easier to find or cheaper at your local autoparts store.
Old Jun 24, 2005 | 11:46 AM
Black Maxima
Thanks for all your help and the thorough reply. As usual I have more questions. Where is the SPDT/SPST relay? Seems like I'll have to buy one. But, this will be a cool mod. When I get some time, I will try doing it.
I'm going to go out to my car and look for the remote control relay.
Thanks, Aaron
Old Jun 24, 2005 | 12:23 PM
NotNew!!NewSN!!'s Avatar
I have been tryiing so hard to get a pin out/schematic of the wireless remote system receiver that is located in the passenger side wall of the trunk in my 95 maxima. Anyone?
Old Jun 24, 2005 | 01:01 PM
Travibe's Avatar
hmmm
i have been thinking about doing this to my max ... just havent actually gone through with it. Maybe this weekend ill see what i can do..gotta borrow some tools and get to a store to find the schtuff. Any suggestsion on where would be the best place too look for something like this? is it in a kit or seperate parts?
Old Jun 24, 2005 | 11:26 PM
sparkyssb's Avatar
ok guys...apparently you are new to electronics and I was not aware so I appologize for posts without more information. To start off with, this is all done with parts you pick up in your locality. It is not a kit....it is a simple design of a circuit that I made up using certain parts that you have to buy. First, the SPDT or SPST relay is in essence an electronic switch. You can pick one up at your favorite autoparts store. Look in the section near the foglights because a SPST relay is most commonly used for a foglight setup. You can pick up a SPST (4 pin) for about 5 bucks or less. If you went with a SPDT relay (5 pin) it would usually cost a little more so just go with the first one. If you have trouble finding a relay, talk to a person there and they will (should) be able to get you one right away.
You should also get some crimpable connectors to connect your wires to the relay. You will find these also in the autoparts store. You will want the female type. Here is a picture of what they look like.
Last but not least you will also probably want to pick up a package of plastic self tappers. It will make the tap into the horn and remote control relay easy.
They look like this. (the red plastic thing; the wiring is not included)
Because this is new to you, do not attempt to wire in a diode....for this basic setup, it is not needed.
So all together, you only need 3 cheap items to make this work; all available at your autostore. Use the above directions to install it and you should be golden.
Old Jul 7, 2005 | 10:15 AM
anyoneeeeeeeeeeeeeeee????????
scutmud
Aug 16, 2018 10:56 AM
kmitchel
Oct 28, 2015 09:46 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
bc992164
Aug 26, 2015 12:19 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
