Installed SP2
Installed SP2
Just installed my Greddy SP2 yesterday! It's sounds tight, but its gonna take some getting used to. Its obviously louder and I'm not 100% happy with that big *** muffler tip. But, overall....Its THE SH**.
Anyway, installation was a Biitch since my factory exhaust system turned out to be all rusted. The 2 nuts at the cat broke and I had to drive the car to a local shop to complete the installation. They got me for big time $$$. So now that's done, I will be installing my Iluminas and Maxspeed springs today. Hope everything goes smoothly with that.
It depends on the year If you use the O2 sensor hole on the B-pipe or on the Cat... 97-99 use the bung hole on the cat while the earlier years before 97 use the bung hole on the B-pipe...
Congrads on your new SP2... I got the jokes about the coffee can tip but that muffler sounds soooo sweeet.... I love mine
Click link for some pics:
here
here
here
here
Originally Posted by joosdawg
hello, i think everyone should know that by now. do u understand that even in the 95-96 GREDDY theres an O2 bung in the B pipe! im just saying i was trying to figure out if the 95-96 greddy has the same or differnt size o2 bung on the b pipe sense they both have it.
I think you guys got that reversed, my 96 has it on the cat and as far as i know so do all 95-96's, i imagine the reasons for greddy not fiting a 97+ is much like the apexi, 0n a 97 the tip will sit under the rear bumper and posibly burn it and there isnt a bung on the b pipe for an o2, i could be wrong though
--Dan
omfg you guys are retarted, the 95-96 stock has the O2 in the cat but the 95-96 greddy has a hole for it in the b pipe. the 97-99 has the O2 in the b pipe in both stock and greddy. theres two differnt greddys! the 95-96 fits better on the 97-99 reason being greddy makes the tips always like 2 in to long so u can see that it says greddy. if you put the 95 on a 97+ its exacly even with the bumper its just the fact if the O2 sensor bung in the 95-96 one is to big for the 97-99 sensor or not! everything fits its just the hole!!! once again BOTH greddy systems have a hole for an O2 sensor in the B PIPE! get it right
calm down bro...go have a smoke or somthin
you can see where there would be confusion seeing as how the greddy is obviously not a direct fit for a 95-96...thanks for clarifying it anyway
guess i wont be doing a greddy to replace the apexi, im not throwing away a 200 dollar aftermarket cat
--Dan
--Dan
Originally Posted by 1NICEMAX
LOL, anyone know what modifications exactly need to be done to fit an sp2 in a 97-99??
Originally Posted by XoPtOn
if you are cali spec, you dont need to do anything except close the extra o2 sensor hole on the b pipe. Thats what i had to do on my 99
so the only problem with 97-99 is that there will be a HOLE to be filled correct?
BORQUA79 is that a 95-96 sp2 on your car? if so can anyone post pics of a 97-99 sp2 on a 97-99? I think i'd rather deal with the stick-out more than having a shop weld on the correct bunge =)
The difference is that on a 97-99 the tip is more flush like mine... On a 96 the tip would stick out more. On my car they plugged the O2 hole on my B-pipe and used the hole on my Hi-Flow cat for the O2 sensor.... All they did was use a bolt to plug it. On a 96 Its a direct fit and you use the hole on the B-pipe like your original 96 O2 sensor...
Remember: 97-99
1) Plug hole on SP2 B-pipe with bolt
2) The muffler is flush with rear bumper
96 and below
1) Use SP2 B-pipe hole for O2 Sensor (like they tell you because this was made for you 96 and below owners)
2) Muffler sticks out a little more
For pics on a 98 click here
Personally Ive never heard of a 97-99 Sp2??? I have the only one they offered at the time the pre-97 SP2. They said that It wouldnt fit on my 98 but they are wrong It looks fine to me...
Remember: 97-99
96 and below
Remember: 97-99
96 and below
ok as stated above with my confusion about this...95-96 OEM exhaust does not have an o2 sensor in the b pipe, it is in the cat, 95-96 will be the ones that need to have the hole plugged. 97-99 OEM exhaust has o2 sensor in b pipe, the O2 sensor on the 97-99 may or may not fit the hole on the greddy b pipe
--Dan
Remember: 97-99
96 and below
Remember: 97-99
96 and below
Remember: 97-99
96 and below
Remember: 97-99
96 and below
Don't forget the early 97's use the B pipe bung, NOT the cat bung. Like my 97 which rolled out of the factory in march.
--Dan
--Dan
if you have doubts then get the 97-99 greddy specs...: item#:10127022 - 97-99 SP2 or if you really feel the need then get the 95-96 one which is item#10127020 - 95-96 SP2 theres two model #'s for anyone who thinks they both dont exsist call greddy and ask about those youll have your answer.
i have some but im not gonna waste my server space with them basically its very deep and bassy but not loud at all if you have an intake the intake will overpower the exhaust for sure. its just alot deeper and little louder than stock nothing like with a y pipe and absolutly no rasp just bassy note. sounds good like that but no power without the y i say
Originally Posted by DragonMaxima
Thanks.
How about at idle? Would the noise be too annoying?
wait, 1st off dont go assuming everybody bought the inncorrect highflow cat let alone has a differnt cat period. with that being said its obvious u urself must have gotten a 95-96 highflow cat...besides you everyone that has a normal 97-99 uses the hole in the b pipe idk what kind of crack your car is on
My O2 Sensor on my 98 SE is in the B-pipe bung supplied by Greddy (SP2 95-96) I have a Hi Flow Cat that has the O2 sensor bung in it that Ive plugged... Due to the angle the O2 sensor sticks out, I broke the sensor. The OE bung pointed up and away from the hazards of a lowered ride. This should have been incorperated in the new design... I have to call Greddy about that.
So Heres my set up be it on crack or not
Heres the pics to prove it:
More pictures here
MaxLife17
Jun 27, 2019 01:37 PM
too much gt4 for us my friend
