slammed on the brakes while driving around 50mph...
Old Mar 7, 2005 | 09:17 PM
ShRapNeR's Avatar
eh.. driving down the highway minding my own buisness when all of a sudden this guy decides he wants in my lane...
had to slam on the brakes to keep from hitting him...
just got on the highway and was speeding up to 70..
well anyway now my frontend shakes and the steering wheel ect.. but only when i get up to around 60mph or more...
what could be wrong?
Old Mar 7, 2005 | 09:20 PM
askorbik's Avatar
maybe your brake pads or caliper is riding against the rotor?
Old Mar 7, 2005 | 09:42 PM
bananamax's Avatar
If a sudden slow-down (let alone stop) from 70mph causes a change in your car's braking ability,(eg. shakes) perhaps you need to invest some serious time/money in the brake system as a whole. My quess is that the rotors are "slightly" warped.
Old Mar 7, 2005 | 09:46 PM
suicidalspd99
i think the rotors and warped. yeah if that caused a problem i would check things out. maybe its time for powerslot rotors.
Old Mar 7, 2005 | 11:17 PM
Ant96GLE's Avatar
If they are vibrating now.. I would say they are warped. Long fast braking distances with stockish rotors will cause your rotors to get warped.
Old Mar 8, 2005 | 12:55 AM
Maximus_95's Avatar
oh darn, that sucks, i guess its time for bbk!
Old Mar 8, 2005 | 01:02 AM
MainSource's Avatar
Hit 'em with the stun gun
What does short, hard braking do then...cuz my brakes are feeling a little wimpish right now?
Old Mar 8, 2005 | 04:04 AM
Chickan's Avatar
could result in the same. Anything strenous on stock rotors can lead to problems.
Old Mar 8, 2005 | 05:03 AM
mzmtg's Avatar
Minister of Silly Walks
If you locked up the tires, you could have flat spotted them.
Get new tires.
Old Mar 8, 2005 | 05:05 AM
deezo's Avatar
Get new tires.
Old Mar 8, 2005 | 05:07 AM
njmaxseltd's Avatar
Get new tires.
You got that right, a lock up at 70MPH will definately cause flat spots on your tires. Your rotors can't warp up on one panic stop, takes quite a few rapid heat ups and cooling cycles before the rotor surface becomes uneven. It happens gradually, not all at once.
Old Mar 8, 2005 | 05:08 AM
mzmtg's Avatar
I did it once. I locked up my brand new tires from 65mph all the way to a dead stop. Needless to say, they were totally ruined.
Old Mar 8, 2005 | 06:04 AM
PAREDLINE's Avatar
Get your wheels balanced, they'll spin the tires and tell you if there are flat spots right then and there.
Old Mar 8, 2005 | 08:06 AM
bignutts
time for some bremo's rotor or you can go stillen
Old Mar 8, 2005 | 08:27 AM
mzmtg's Avatar
If you dont know what you are talking about, don't post.
Old Mar 8, 2005 | 08:29 AM
MaDMvD's Avatar
This guy must be some kind of undercover annoyance from a Honda forum or something, just here to annoy us with moronic comments.
Old Mar 8, 2005 | 09:14 AM
adithius's Avatar
Well are you braking when you feel the vibration? If you apply the brakes and they shake, then they are warped.
I think your most likely out of balance on your tires. Get a balance and an alignment.
Sorry to hear about your problem.
Old Mar 8, 2005 | 09:17 AM
adithius's Avatar
This put a post up on what he should do with his flat tire.
Old Mar 8, 2005 | 09:18 AM
2 Da Max's Avatar
flat spots? dam if you have abs would this still happen?
Old Mar 8, 2005 | 09:20 AM
adithius's Avatar
Sometimes.
Old Mar 8, 2005 | 09:38 AM
*FleXIMA*'s Avatar
shrapner, something like that happened to me a little while ago, I stopped short and rubbed of a certain part of the tires, winds up i just need 2 new tires so check it out it mite be as simple as that.
Old Mar 8, 2005 | 10:07 AM
deezo's Avatar
Don't worry, his days are numbered.
Old Mar 8, 2005 | 10:14 AM
MaxGordon7's Avatar
rofl if just hitting my brakes hard once will toast my rotors or tires then i need to get those 300zx calipers. Just replaced with front left caplier with an OEM, it was locking up bad. Put 500 bucks into my tires and have slotted/drilled brembo rotors coming with kevlar pads.
Maximus_95's Avatar
If i was you, i would first balance, and then if it still does that, it could be your alignment. i dont think doing 1 hard brake would warp the rotors just like that.
maybe if you braked hard, and kept on holding on the brake, then yes, its warped. just imagine your rotors super hot and your brake pads just resting on it, that's a big nono!
Old Mar 8, 2005 | 10:15 AM
deezo's Avatar
Of course not. This only happens when the tire locked in position.
Old Mar 8, 2005 | 10:57 AM
bignutts
what does that mean
Old Mar 8, 2005 | 11:00 AM
Flava_24/7's Avatar
Boosted Panda
what does that mean
Old Mar 8, 2005 | 11:01 AM
2 Da Max's Avatar
lol, 2 funny flavor
Old Mar 8, 2005 | 01:53 PM
ShRapNeR's Avatar
Get new tires.
thats what i thought... but its been 4 months or more since this happend..
and it shakes when im driving normal not really when im braking.. (does a little but not alot)
Old Mar 8, 2005 | 01:56 PM
ShRapNeR's Avatar
the same day.. before this happend i had my tires balanced rotated and my rotors turned... so i dunno..
ill get them balanced and aligned possibly later today if i can..
thnx for the help..
i also read that a torn cv boot can eventually make your car shake or something... this is most likely not the problem is it?
Old Mar 8, 2005 | 02:11 PM
deezo's Avatar
what does that mean
You can do that to me when you see me at a local meet. For now, you're permed.
Old Mar 10, 2005 | 04:24 PM
ShRapNeR's Avatar
kk.. took it to the shop..
one tire is very badly flatspotted.. the other is just meh.
(had them rotated a while back after it happend)
anyway they coudnl't balance the flatspotted tires... so they just done the front two and then switched sides with them.
also had them look at the leak im having and it is infac coming from rear vavle cover.
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
crazyespn
Sep 3, 2015 01:30 PM
