If you've replaced your ignition coils recently, read in here!
Old Mar 16, 2005 | 04:24 PM
  #41
Fork's Avatar
Maximaler Experte
The funny thing is grey - it easier to change the coils than is it change the oil - by around 15 minutes. Heck, my dog drunk on nyquil could change the coils.
My fustration is the fact that I can't get coils up here cheaper than $100USD each from any parts store and no one has it in stock / not even junk-yards. I heard of a place for $60 - where are you guys buying it from?
Old Mar 16, 2005 | 05:57 PM
  #42
PAREDLINE's Avatar
www.rockauto.com. I don't know if they deliver to Canadia.
Old Nov 5, 2005 | 10:09 AM
  #43
edacs1's Avatar
How to install ignition coils - 2000
This reply is for anyone looking for detail on how to install ignition coils. I just installed all 6 in my 2000 Maxima in under an hour. It could have taken less time if I didn't drop a screw!
There are two types of coils - 3 for the front and 3 for the rear. I ordered them from Woodmen Nissan in Colorado (a wholesale Nissan parts dealer) for $59 each plus freight but without tax to Illinois. See them at http://www.trademotion.com/partlocat...cfm?siteid=722
As mentioned, the coils in the front are located under the plastic cover that says Nissan V6 3000. The cover is held on by four screws that can be removed with an allen wrench.
The front coils are held in place by one bolt each. Unscrew the bolt, pull the coil partway out, and release the wire by pushing on the connector. Simple!
The rear coils are in the back of the engine. They're harder to reach but the process for removal is the same - remove the screw, pop off the connecter, and pull out the coil. I couldn't get enough leverage to push on the connector with my finger so I used a socket extension - pushing on the button while using my other hand to pull off the cap.
I had a bit of difficulty putting in the new coil on the rear drivers side so I loosened the two bolts holding the throttle cable. I moved the cables an inch or so out of the way. This gave the coil a straight path which allowed it to go right in.
Tools required were a metric socket, 6" extension, and driver plus an allen wrench. My shop quoted over $1,000 for parts and installation. I paid less than $400 for the coils and freight. That's the first time I've been paid $600 an hour for anything!
Old Nov 5, 2005 | 11:32 AM
  #44
PAREDLINE's Avatar
What do you want a cookie or something? Just kidding. Good work newjack. You probably saved like $500 from going to the dealer. Does it feel good?
Old Nov 5, 2005 | 12:03 PM
  #45
Groundz's Avatar
I've only had one coil pack go and that was at around 80k. And yes I do have the sh!ty hanshin coils. But like I said only one has ever given me any troubles. Also, it's the owners responsibility to keep thier car in good running condition. Mechanical and electrical parts fail everyday, Why do you think warranties expire? Warranties don't go bad, the parts they cover do and the manufacturer's know this and adjust the availibility of a warranty accordingly.
Old Nov 5, 2005 | 12:45 PM
  #46
goldtooth's Avatar
wow, you guys just WANT to pay for ignition coils , and since you WANT him to lose, then you all might as well buy ignition coils for all of us. cuz I know for sure I wouldnt mind new coils. (douschebags....)
Old Nov 5, 2005 | 01:09 PM
  #47
Eric23's Avatar
Since we're on the subject of ign. coils... My daughter's '99 I30 had the CEL come on, bought the code reader, came up with P1320 & P0304. After reading all of the posts , checked the coils with an ohm meter and they checked out fine. The car runs ok, although she did report intermittant rough idling. I erased the codes and took it for a long test ride, the light stayed off and it runs good. Any other items I should check that could be related to those CEL codes? Thanks
Old Nov 5, 2005 | 01:40 PM
  #48
Groundz's Avatar
Did you check the CPS, (cam position sensor)
Old Nov 8, 2005 | 02:36 PM
  #49
Eric23's Avatar
I'm going to replace an ignition coil this evening. The Haynes manual says to disconnect the battery. Not particularly wanting to disrupt my daughter's radio pre-sets etc. it would be nice not to have to go through that step. Certainly don't want to fry myself or any circuitry just to appease my daughter. Any feedback? BTW the CEL came on again and got another P1320 code. I've come to the conclusion that my inexpensive Walmart mulitmeter is probably not up to the task of correctly testing the coils.
Old Nov 8, 2005 | 02:39 PM
  #50
njmodi's Avatar
Do I get a tax break?
Time for 6 new igintion coils. Disconnect the battery. I can't believe reprogramming the presets is an issue... damn, tough cookies...
Old Nov 8, 2005 | 03:47 PM
  #51
nismology's Avatar
This thread is just full of it. My god if i was a mod this thread would've been locked before the 2nd page started.
Old Dec 30, 2005 | 11:30 PM
  #52
maxima_kid's Avatar
Can 00-01 coils work for 99s or any other 4th gens?
vingodine
45
May 21, 2016 12:46 PM
KRMZN603
Sep 13, 2015 08:36 AM
Maxboy23
Aug 21, 2015 11:02 AM
Balkins
Aug 12, 2015 06:39 AM
maxima297
Aug 3, 2015 12:50 PM
