help installing Hella Supertone horns
Old Apr 5, 2005 | 05:35 PM
XIMA96SE's Avatar
I need help installing hella superton horn. i tried search but i coudnt find a write up
thanks in advance
mo
Old Apr 5, 2005 | 09:44 PM
killerVQ30DE's Avatar
Check my airhorn setup, using triple horns
Theres a HOWTO in the 4th Gen HOWTOs stickies
Old Apr 5, 2005 | 09:48 PM
I30_DRIVER's Avatar
i got six trumpets ( la cucaracha )
its easy you take the wire from the original horn connect it to the possitive on the compressor ground the second wire coming from the compressor to a solid meatal replace the stock 7.5 amp fuse with a 20amp disconnect the rest of original horns and done (and no it is not nessesery to use that relay original is good enough)
Old Apr 5, 2005 | 10:00 PM
Hopefully you don't have your horns yet...
'Cos theres heaps to choose from
2 horns = loud but not harsh
3 horns = loud and grating, people know your honking it
And then theres the musical ones like the 6 trumpet above, and I also saw triple horn with adjustable tune(?)
Old Apr 5, 2005 | 10:08 PM
I30_DRIVER's Avatar
i had mega tone in my i30t the truck ones 2 trumpets with an air suplied compressor
Old Apr 5, 2005 | 10:10 PM
Hmmm all air horns are compressor driven aren't they
Old Apr 5, 2005 | 10:11 PM
I30_DRIVER's Avatar
it had a separate air tank then a compressor it would build up air int he tank then when you honk it goes wwwooooooo
Old Apr 5, 2005 | 10:27 PM
bigtimber's Avatar
Here's the writeup: http://web.archive.org/web/200111091...max/horns.html
you can really mount the horns wherever you want, and a relay is not required but you might want to run one anyway. i have blown the fuse twice and have had the horns for about 2 years.
it's really easy
Old Apr 5, 2005 | 10:35 PM
It comes with the relay anyways so just buy a $2 packet of crimp tab connectors and then you have no worries about blowing fuses
Old Apr 6, 2005 | 03:53 AM
ronin22357's Avatar
-Use the relay: Connect the stock horn wire for your turn on, run a wire off the positive battery terminal for your power, find a good ground to ground it, run the wire to the horn(s) you have to tap another wire off it since you have 2 horns.
-the horns themselves have a ground, I grounded it to the metal that I mounted them too.
Hope this helps, they sound really good
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
