something is wrong !
Old May 13, 2001 | 11:51 AM
Tri-lite's Avatar
I have a 96 GXE 5 spd. and I can't put it in fisrt or second!! usualy you can pull the shifter towards you and pop it in first or second but it won't go passed third and forth gear i could go fift and reverse with out any trouble.... now if i want to bring it in to get it fixed I have to start from third gear ... and try to not stop the hole way there ...
do I need a new clutch ??
btw the clutch was doing some noises before. I was told the berings in the clutch was no good ....
any info would be nice...
Old May 13, 2001 | 12:50 PM
Daniel B. Martin's Avatar
Thank you for the detailed description of symptoms. It does not sound like a bad clutch. More likely it is a problem with the shifter or the interlock mechanism inside the transmission. Let's hope it is the shifter because removing and opening the transmission will be expensive.
Old May 13, 2001 | 06:16 PM
Tri-lite's Avatar
yeah it's going in this week ASAP so will see what the deal is ... I'll let you know how it goes
Old Oct 5, 2002 | 11:11 AM
kurdtis's Avatar
I am having the same problem with my i30t 5sp. Roswell Infiniti told me the problem was the clutch and charged me over $1200 to replace it. At the first light I stopped at, the problem happened again! I was ****ed. I started in 3rd gear (happily burning my brand new - maxed out the discover card clutch) and drove back to the dealership. This was yesterday. Today I have had 1 phone call stating they cannot duplicate the problem -- but they will say they will drive it again and call me later. This sucks.
What did your problem end up being? How much did it cost to fix?
Forge277
Jun 13, 2016 09:26 PM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
220k+ A32
Sep 11, 2015 02:18 AM
