Need help with 0503
Old May 17, 2005 | 09:51 PM
Shift_my vq's Avatar
Need help with 0503
Just wondering if any body can tell me more in detail what 02 censor that. I replaced the highest one on the y pipe that sticks out to the right if your facing the car. Then reset the ecu and came back. Thanks ahead of time guys.
Old May 17, 2005 | 10:15 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
0503
Diagnostic Trouble Code 0503 indicates a problem with the front Oxygen Sensor on the right cylinder bank. The right bank is also called the rear bank. It is cylinders 1,3,5. A normal signal sweeps back and forth between 0.2 volts and 0.8 volts. This malfunction was detected when the Engine Control Module received a signal from the sensor which was a constant value of approximately 0.3 volts.
Possible causes include ...
- Harness or connectors (the sensor circuit is open or shorted).
- Defective Oxygen Sensor
this is for the second o2 sensor(the middle of 3 total) in the y-pipe. the one you replaced is called the Front Left O2 Sensor, the one you have to replace is the Front Right. same part as the one you replaced. they are about $60 at oxygensensors.com
Old May 18, 2005 | 10:11 AM
Fork's Avatar
Maximaler Experte
Just got my order from oxygensensors.com - those guys are good. I called my order in just to be sure.
Old May 18, 2005 | 10:46 AM
njmodi's Avatar
Do I get a tax break?
If you still have the sensor that you replaced - i.e the old one, you can use that to replace the one that is really bad (the front right - closest to the firewall on the y-pipe).
apeg
Apr 10, 2005 08:09 PM
Mark97SE
Sep 9, 2004 02:22 PM
DemonSpawn
Jun 14, 2004 01:40 PM
95maxrider
Sep 29, 2003 07:22 AM
