UDP!! question/help
Old May 21, 2005 | 01:51 PM
drivinmax
UDP!! question/help
this past weekend i got my udp and i went to install it, got everything taken after and i couldnt get the stock crank pulley off, i used an impact gun that didnt work then i tried it by hand used a strap wrench and a braker bar that failed also, whats the deal?
i called nissan and they said its a normal bolt not left handed or anything
Old May 21, 2005 | 01:58 PM
maximazation's Avatar
did you try using a pulley remover tool?
Old May 21, 2005 | 02:01 PM
drivinmax
no i cant get the bolt off thats the problem
Old May 21, 2005 | 02:05 PM
aznsap's Avatar
i put a metal pipe around my breaker bar, so that it extended to rest on the ground. then i turned my car (NOT STARTED) to break the bolt loose.
Old May 21, 2005 | 02:10 PM
drivinmax
is that safe?
Old May 21, 2005 | 02:15 PM
Magikone69's Avatar
tried using some wd40 or similar product?, that pb blaster (?) stuff i have works really weel with tough bolts/screws
Old May 21, 2005 | 03:28 PM
drivinmax
yup i used both
Old May 21, 2005 | 03:54 PM
ronin22357's Avatar
are you auto or 5 speed?
If your auto you have to lock the fly wheel or else you will never get that bolt off.
Old May 21, 2005 | 03:57 PM
drivinmax
its auto thats not the problem either the motor doesnt turn that much i still cant get the damn bolt off
Old May 21, 2005 | 06:38 PM
aznsap's Avatar
u sure? that's how i did it. i even have a video of it. here's a pic:
you can check page 4 of my cardomain, that may help. just crank your car (but don't let it start). the starter should have enough power to break the bolt loose.
Old May 21, 2005 | 06:48 PM
drivinmax
alright good looking out man also what is the exact way to do this cuz to me it doesnt sound safe but whatever it take you know
Dave B
May 29, 2001 11:07 AM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
ohboiya
Oct 9, 2000 12:23 PM
