Cleaning inside of Intake Manifold... what do I use???
Old 05-25-2005, 11:52 AM
CleanMAX98's Avatar
I recently got an IM off a max with 170k on it, i am in the process of polishing it but i looked inside the IM and it is all black and dirty looking, how would I go about cleaning the inside so there is better air flow???
Thanks guys
CleanMAX98 is offline
Old 05-25-2005, 11:54 AM
dot dot dot ...
NmexMAX's Avatar
Not sure if it will help airflow out by much, but usually carb/TB cleaner will do the trick .
NmexMAX is offline
Old 05-25-2005, 11:59 AM
joeeey's Avatar
Or you can purchase intake cleaner, but carb/tb cleaner should be fine.
joeeey is offline
Bobo's Avatar
Like NmexMAX says. But what would possess you to buy an intake manifold with 170K on it? What was wrong with the one you had? Couldn't you find one to replace it with fewer miles. I'm not sure if it would make a difference if it was 70K or 170K.
Bobo is offline
Old 05-25-2005, 12:00 PM
dot dot dot ...
NmexMAX's Avatar
I coud've sold you my old one ...
NmexMAX is offline
Old 05-25-2005, 12:09 PM
CleanMAX98's Avatar
im polishing the one i have, they are both the same 4th gen style, it is much easier to polish it while it is off the car
Old 05-25-2005, 12:12 PM
Bobo's Avatar
Is there such a thing as an acid bath or something you can immerse the intake manifold in? How do they clean up heads, pistons and crankshafts etc. when engines are rebuilt?
Bobo is offline
Old 05-25-2005, 12:13 PM
CleanMAX98's Avatar
ill have to ask on that.... good idea
Old 05-25-2005, 12:35 PM
dayglo's Avatar
anyone have a write up on removal and cleaning of the IM? i would go in and pop the thing off...but i dont want springs and engine parts to fly out at me. just so i know what to look out for and what to clean
dayglo is offline
Maximan190
12-16-2015 06:01 AM
bumpypickle
09-20-2015 08:22 AM
seesole
09-14-2015 12:38 PM
Quick Reply: Cleaning inside of Intake Manifold... what do I use???
