Anti-theft
Old Jun 4, 2005 | 10:49 PM
DonOfDesperados's Avatar
Anti-theft
My wife recently knocked the anti theft chip out from under the steering wheel area. She tried and started it and it wouldnt start (no ****) so i plug it back up and try and start and it wont start unless i give it some gas while cranking it. Any tips on how to reset the anti theft or if the fuel pump or any help about whats wrong. thanks'
Old Jun 5, 2005 | 06:40 AM
Chickan's Avatar
take the ground cable off of your battery for an hour?
Old Jun 5, 2005 | 07:16 AM
PandaXpress's Avatar
if there is a relay..reset the relay..it should work after
Old Jun 5, 2005 | 11:19 AM
I have'nt tried the Negative wired yet. But just in case that doesnt work. Where and how would i reset the relay. thank you
Old Jun 5, 2005 | 04:44 PM
bumped.......
Old Jun 7, 2005 | 01:59 PM
bumpped.....
Old Jun 9, 2005 | 01:59 PM
Well i disconnected the negative wire and left it off for about an hour. I plugged it back up and still it wouldn't start like normal. I checked the anti theft fuse and its good and i Don't know how to reset the relay.
Old Jun 9, 2005 | 02:04 PM
njmodi's Avatar
Do I get a tax break?
I don't think the hard starting is related to the anti-theft at all. If the anti-theft was enabled the car wouldn't start no matter what you do. From your post, it seems as though the car starts... just not easily.
Old Jun 9, 2005 | 02:10 PM
Only reason on why I believe the ait theft had soemthing to do with it. Is because when my wife knocked it out. She kept trying to start it and it would start. 6 months later when I come back from a deployment. I plug the chip back in and try and start it and i gave to give it gas while cranking the engine. sometimes that doesnt even work. I check the TB and it is cleaned. No codes are showing up so im clueless.
Old Jun 9, 2005 | 02:11 PM
njmodi's Avatar
If I understand correctly, your car sat unused for 6 months - since it wouldn't start.... well damn, keeping a car idle for 6 months - I'm not surprised you have some starting issues...
Old Jun 10, 2005 | 02:18 AM
dayglo's Avatar
is gas still good after 6 mo? maybe try a gas additive or something i dunno
Old Jun 10, 2005 | 08:35 AM
to reset a relay..just disconnect it.and reconenct it again.
Old Jun 10, 2005 | 09:11 AM
5alive's Avatar
Do unto others...
You don't even know if there's a realy, but you're telling the guy 'that will fix it'?!!!
mm347
Jan 5, 2005 11:20 AM
izzydig
May 2, 2003 04:51 PM
kriese515
Mar 10, 2003 06:12 PM
PedalKick
Feb 14, 2003 07:05 PM
