replacing the a/c evaporator
Old Jun 8, 2005 | 10:40 AM
tryme's Avatar
has anyone replaced their evaporator core/coil? i have a 95 maxima and midas wants 500 bucks just for one. i can get one for 90 and the labor from midas is 100 bucks i assume 2 hours of labor so i want to do it myself. anyone know?
thanks
Old Jun 9, 2005 | 03:55 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
put system in a vaccum. remove glove box, remove metal bar, cut off plastic bar, remove 2 retaing clips, remove 2 tiny screws and the remove 4 large screws securing the evaporator. R&R. and then R&R the reciever drier. then recharge.
Old Jun 9, 2005 | 04:17 AM
njmaxseltd's Avatar
killcrap makes it sound so easy...
Old Jun 9, 2005 | 07:03 AM
eturnl
haha! for sure!
Old Jun 9, 2005 | 12:00 PM
s0ber's Avatar
I did it, it is easy... Takes about 45minutes
Old Jun 9, 2005 | 12:03 PM
renatonetmail
what's the a/c evaporator? and how exactly do you know is failing and/or need to be replaced? thanks
Old Jun 10, 2005 | 08:11 AM
Max747's Avatar
That's where the air gets cooled and dehumidified. You should be getting cold air at about 60 degrees or so. Higher temps indicate that either you don't have refrigerant or the coils aren't colling.
Old Jun 12, 2005 | 08:47 AM
davey6693's Avatar
I pulled mine to replace the expansion valve. Exactly what killcrap said, plus replace the o-rings. It's not too bad of a job, you'll just need them to evac and recharge for you.
PH98I30
29
Feb 10, 2025 12:03 PM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
