F'ed up tach
Old Jun 14, 2005 | 06:27 AM
sdoherty_tjm's Avatar
F'ed up tach
95 5spd with a tach that goes to 7300 in first 7000 in second, if you race the engine in neutral, the rev limiter bounces when the tach gets to 4k. in any gear its about 6-8 hundred off. anybody know how the hell im supposed to fix that? Do i need an entirely new gauge cluster? i have to replace my CEL anyway, so should i get that done?
thanks for the help in advance
Old Jun 14, 2005 | 07:15 AM
so um....does anyone know anything about this???
Old Jun 14, 2005 | 07:22 AM
njmodi's Avatar
Do I get a tax break?
Most likely the tachometer is bad - you'll need to replace the entire cluster.
Old Jun 14, 2005 | 07:27 AM
if i do dont i have to get a dealership to spin to odometer? happen to know the cost of that?
Old Jun 14, 2005 | 07:29 AM
Killer99max's Avatar
Custom Molding King!
You don't need to replace the whole cluster, all you have to replace is the rpm gauge, each gauge comes apart seperatly, and you can just buy that used, or find it new from the delaer, I will let you know if I can find you a used replacement for a reasonsable price, I will keep you updated.
Old Jun 14, 2005 | 07:30 AM
njmodi's Avatar
Technically yes - but you could try to find one with about the same miles (from either a junk yard or here on the ORG - check the classifieds forum) and just swap it out. I imagine a new cluster or just the tach would be quite expensive - including the calibration - I would guess > $300.
Old Jun 14, 2005 | 07:32 AM
thanks
i have ~103,000 miles on mine
if anyone could hook me up with one that would be nice
Old Jun 14, 2005 | 08:51 AM
maxspeed96CT's Avatar
The original VQ...
you can replace the the tach part, and leave your regular speedo, this way you just pop a new tach into your cluster and it will be perfect.
You wont have to change needles or anything..
Old Jun 14, 2005 | 08:53 AM
i think the needle might be the problem though, cus when i turn the car of, it takes about three seconds to fully drop to the bottom
its reallly ****ing retarded
maximaham
Aug 7, 2015 01:11 PM
Pat DiPersia
Jul 11, 2001 03:05 AM
sleeper
Jul 10, 2001 06:40 PM
sleeper
Jul 7, 2001 07:36 PM
jetmax
May 1, 2001 12:18 AM
