Y-pipe in fed spec car registered in cali
Originally posted by ionicmax
Hello:
I was thinking about getting a y-pipe in my 98 Max. My question is will my car pass emissions here in California with the y-pipe installed, considering it's a fed spec car?
Hello:
Originally posted by Adidas_Boy
The car should pass smog as long as the engine is warm, give it a good work out before. The Y-pipe gets rid of the pre-cat, and so when the engine is warm you will get the same emissions as you would with the stock one (from what I have been told). So if it would pass with the stock one it will pass with the aftermarket one as long as the engine is warm.
So it doesn't matter that my car is fed spec and that I'm in California? Thanks for the input!
Well, you have to get it registered in CA, and if it has to be modded to be in the state, that is when they will tell you. . . It really sucks. . . But hopefully they won't make you change anything.
Cool!!! Thanks
Here's some info
Skimax had to get his car smogged. He failed on first attempt, he got something like 900+ NOx count. The limit was 820 or something like that. Well he went home, installed teh stock Ypipe, came back and had a NOx count of 2. Yes TWO not 200, but just 2. So yeah it makes a big-a$$ diff.
Originally posted by BrianV
Here's some info
Here's some info
Wow!
Here's some info
Here's some info
Lakersallday24
06-16-2019 01:35 AM
Team STILLEN
08-10-2015 04:29 PM
1992maximase30
08-05-2015 09:27 PM
