help keyless entry oem won't work??
Old Jul 6, 2005 | 06:43 PM
achebee4you's Avatar
so i just got my car back from getting it tinted with the solar guard reflective tint 28% front and 14% rear
so when i hit the unlock and lock button on my remote it won't work, im so pissed, i hope it isn't the tint, does anyone know where the transmitter is in the car that recieves the signal to unlock/lock and panic the alarm is?
plus i changed the battery and it still won't work, damn im frustrated, i mean the tint is reflective but would that mess up the signal, but i also tried it while i was inside no luck, any help would be usefull its the oem unit
Old Jul 6, 2005 | 06:51 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Same thing happen to me too when I got my tints done. Check the ELEC fuse which is in the cabin of the car. The ELEC fuse is in the top right hand side corner. Check if it is blown. In my case, it was not but simply the action of me taking it out and reinserting it, my keyless entry worked again.
Old Jul 6, 2005 | 06:55 PM
ok, ill check it out i hope that the problem, bc i wouldn't think tint could interfere with the keyless entry
Old Jul 6, 2005 | 07:02 PM
ImmaSquashYou's Avatar
umm....did you try it while you were IN the car?? if it doesn't work while your IN the car. then there is something wrong with the remote or module itself. if it does work INSIDE the car and not OUTSIDE the car. USUALLY tints won't reflect signals such as a remote unless you have the tints that have metallic layers inside
Old Jul 6, 2005 | 07:04 PM
i jsut did it it works thanks man, i love the internet
Old Jul 6, 2005 | 07:05 PM
Black Maxima
Read through this thread:
http://forums.maxima.org/showthread.php?t=414751
Btheman80
May 1, 2018 04:03 PM
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
BobMax
Aug 15, 2015 12:35 PM
kenc15
Aug 5, 2015 08:29 AM
