fog lights
Don't know about '96 but on my '98 its like 10mins to take out and put back both just need 10mm socket with extension, phillips screw driver(better socket as screws may be rusted) There are two bolts on the inner side of the each fog and use phillips to remove the plastic peace that covers the bolts Hope that helps and works in your case .
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
wow. this is a piece of cake.
1) dont worry about the plastic piece, jsut wedge a flathead in there and pry it off. dont worry about breaking it unless you put the pressure on the wrong spot. the snap should just pop off.
2) I forget if its one or two 10mm bolts, but it/they hold the light onto the bracket.
3) Pull the light out and do what you need to it
4) Reinstall using backwards directions.
The Frye
09-02-2021 11:03 AM
fastcarny
10-06-2015 10:42 AM
-ReLLiK-
09-08-2015 12:02 PM
Maxima30
09-07-2015 06:13 PM
