need your help!! need everyones help!! i tink i blew my tranny again! help plz every1
Old Jul 11, 2005 | 02:14 PM
  #41
2 Da Max's Avatar
Originally Posted by DR-Max
Well it should still be hot to the touch because the external surface still conduct heat. What do you mean by it staying cold in hot days???
its usually feels cold.
this is my question, did my Torq convertere loose oil???
i dont want to drive around with only 7 quarts. i mean i checked my dipstick, and it looks the same from when i added 4 quarts
Old Jul 11, 2005 | 02:20 PM
  #42
DR-Max's Avatar
And what does the dipstick say??
Old Jul 11, 2005 | 02:21 PM
  #43
2 Da Max's Avatar
the residue goes past h
Old Jul 11, 2005 | 02:47 PM
  #44
DR-Max's Avatar
Try driving it around a bit and check the dipstick again. Take your ATF with you. As for the tc, I have no answer for you. The tc on my truck is somewhat warm to the touch in very hot days.
Old Jul 11, 2005 | 05:04 PM
  #45
2 Da Max's Avatar
i dont know guys, the car is type sluggish when i accelarate. sometimes the tranny bogs down a little
Old Jul 11, 2005 | 05:41 PM
  #46
aBoZoG's Avatar
mine does 2 sometimes... never checked the fluid...
Old Jul 11, 2005 | 06:58 PM
  #47
2 Da Max's Avatar
i mean even with my drop resistor mod it still doesnt shift hard. and pick up is garbage compared to it since saturday
Old Jul 11, 2005 | 07:00 PM
  #48
s0ber's Avatar
You probably fried something driving with no fluid
Old Jul 11, 2005 | 07:04 PM
  #49
nismos14's Avatar
§è~® f®ÈÄk
Something in the wiring of you're drop resistor (tranny torturing) mod is not correctly connected or disconnected. At least that's my guess.
Old Jul 11, 2005 | 07:43 PM
  #50
DR-Max's Avatar
I know nothing about the drop resistor mod, but I don't need to because I'm 5 speed. You should VB mod your automatic.
Old Jul 11, 2005 | 07:50 PM
  #51
2 Da Max's Avatar
i just fixed the DR mod, so now its back to stock
what could i have possibly fried in the tranny? there was hardly no metal shavings in the oil pan. and i showed my oil levels to 3 people, and they all said it was good. my dad is a way, but he said there has to be oil in the Torq converter or else you wouldve felt a banging noise, and it wouldnt engage into gear. my final thoughts are............. i didnt had enough tranny oil in there before the accident??
when i drop it into 2nd from drive at low speeds it doesnt jerk hard anymore
wtf
Old Jul 11, 2005 | 07:57 PM
  #52
DR-Max's Avatar
Hey..just out of curiosity, pull out the crankshaft position sensor (POS) located by where the engine and transmission meet, right next to the front engine mount. See if it is covered with metal shavings. Clean the shavings off of it and put it back in. Also, if you know of a trustworthy transmission shop, have them check the TCU for codes. At this point, its really hard to diagnose your problem online. Your next step would be to seek professional help.
wtf
Old Jul 11, 2005 | 08:04 PM
  #53
2 Da Max's Avatar
hhm, ill look into that tommorow Dennis. Neways when i pulled off today, my boys were like dam.. the cars making all that noise but its not launching like it used too.
the only TCU code i had was too much line pressure, beacuse of the Drop resistor mod.. hhm i dont know man.... think the valve body mod would save me guys??
Old Jul 11, 2005 | 08:27 PM
  #54
DR-Max's Avatar
Isn't there someone locally that does the VB mod that you can PM?
Old Jul 12, 2005 | 03:59 AM
  #55
2 Da Max's Avatar
o right,maxima tuning is a couple minutes away from me. lol i dont have any kind of money for that right now though..
can switching to syntec cause this??
Old Jul 12, 2005 | 07:08 AM
  #56
mad-max98's Avatar
try to overfill it turn the car on and engage the gears without loading it then drain it back to normal level,, that will give the tranny a chance to be fully lubricated oh and check your resistor,, i say start saving money for 5 spd cuze autos are very sensitive and once something goes wrong it's a chain reaction so don't be surprised when it goes out b ready and goodluck
Old Jul 12, 2005 | 08:44 AM
  #57
2 Da Max's Avatar
fill it up!! that will blow the seals bro.
and 5spd isnt alot of money, but its alot of work!!
Old Jul 12, 2005 | 09:15 AM
  #58
|Bijan|'s Avatar
UCF Lexus
These auto. guys just dont get it.......these tranny's arent bulletproof
Old Jul 12, 2005 | 09:19 AM
  #59
2 Da Max's Avatar
yes i know this is my 2nd tranny....
Old Jul 12, 2005 | 06:41 PM
  #60
2 Da Max's Avatar
wow i dont know what happened, but for the first time in 2 years, i ve never felt my car pull as hard. today after work i got in the car and i was like fawk it, i gased it hard and the car just launched. the speed was crazy, i never felt my car pull so hard before...
so im guessing everything is fine with the tranny now...
but earlier today it was throwing codes. the OD light flashed 10 times, i just have to find out what it means
Old Jul 12, 2005 | 06:45 PM
  #61
DR-Max's Avatar
I hope you are still planning on getting your TCU scanned. The fact that the problem suddenly disappeared doesn't warrant anything that the problem is fixed. Consider this borrowed time, get your tranny diagnosed properly. Maybe you can still save it from whatever catastrophy is coming, remember silence before the big storm. Just a friendly advise.
Old Jul 12, 2005 | 06:48 PM
  #62
2 Da Max's Avatar
your right, i remember somewhere in the stickies i believe? told you the trouble shooting from the OD light blinking? im still looking for it, can someoen help me find it as well?
Old Jul 12, 2005 | 06:53 PM
  #63
DR-Max's Avatar
I found this: http://turdgens.maxima.org/printthread.php?t=384317 . Scroll down to the bottom and read Kevin's post.
Old Jul 12, 2005 | 06:58 PM
  #64
2 Da Max's Avatar
thanks alot Dennis youve been alot of help.
that is one of the codes the tranny throws, but not the particular one i had. the one i had it flashed 10 times. that other code posted by kevin was like a safety feature.
Apr 16, 2020 05:15 AM
fx4five
Oct 18, 2015 06:57 PM
bernyp
Oct 2, 2015 10:10 AM
fx4five
Oct 1, 2015 04:58 AM
sliptap
Sep 30, 2015 05:57 AM
