resseting computer
Old Jul 11, 2005 | 04:42 AM
mxzmax's Avatar
resseting computer
Ok guys i need to resset it so i can get rid of the engine light. they did it at the garage and it was off for like 2 days, and i need to get my car to pass emissions so could someone tell me how to do it
Old Jul 11, 2005 | 05:23 AM
JSMEXUSA
You have to read the stickies. You need to turn the little screw in the computer next to gas pedal with a little scredriver 95-98 is flat and 99 is a phillips. Turn screw all the way clockwise/right and wait 2-3 seconds at the end, then turn it counter clock wise/left all the way. repeat the same 3-5 times and the light is gone. However try to read the codes to fix your car before you clear them.
Old Jul 11, 2005 | 06:02 AM
mxzmax's Avatar
ok thanks ill try that well one of the codes is the speed sensor and the others are evap and i dont think i have the money to fix them now
Old Jul 11, 2005 | 06:05 AM
Smaynor2934's Avatar
you more than likely wont pass...i did the same thing and i had too amny "unreadies" meaning that the system hadnt had time to process all the components and therefore they could not test about 4 things...you can have one thing not work, but no more than that...good luck...
Old Jul 11, 2005 | 06:13 AM
mxzmax's Avatar
oh ok well i hope ill pass
Old Jul 11, 2005 | 06:27 AM
mxzmax's Avatar
alright i got the code cleared thanks
Old Jul 11, 2005 | 07:22 AM
quaker's Avatar
You will need to drive the car around for at least 2-3 days to let the computer "re-learn" its self. The the computer has to go through a certain number of drive cycles before it will be ready to be tested.
Old Jul 11, 2005 | 07:35 AM
JSMEXUSA
One of my regular mechanics does the inspection at his shop; so if he sees something wrong gives me a break, just give him $20 tip if can not afford to fix car at that time, usually do alignment at same time or something else besides inspection so he makes a little money out of me. If he can't pass it then there are many places that will pass it for a $50-100 tip depending how bad is your car. In case they catch problems act like you didn't know and can't afford to fix it right now, ask them for estimate and for a break, of course you need to tip them as well.
Good luck
Old Jul 11, 2005 | 07:36 AM
Kevlo911's Avatar
Kevlo for President
Wrong, ECU is always learning that is why it is in a closed loop. It does not adjust to a certain driver. It is always reading the sensors to change the maps and stuff.
Old Jul 11, 2005 | 01:41 PM
Batxel's Avatar
blah
I reset my ecu 2 days prior to inspection and I passed the emissions part with flying colors. I currently have had EVAP codes stored for over a year now but I never got around to taking care of it there's always something else to do .... like cleaning the headlights this weeking via kevlo911's "write-up"
Old Jul 11, 2005 | 11:22 PM
quaker's Avatar
In Arizona and Illinois for my 96 max they hook the car to a their computer and if you have reset the ecu resently, a few minutes before to a day or two before, you will fail the test. Well not really fail the test but all of the systems your computer monitors will not have had time to "come on line". It takes a certain number of drive cycles before all systems register.
Old Jul 12, 2005 | 02:00 AM
Prophecy1's Avatar
Its an ECU first off and second off there are plenty of stickies.
Melissa40
Jun 30, 2017 10:04 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
msellas
Sep 23, 2015 09:16 PM
QueensMAX
Sep 15, 2015 04:14 AM
