Lugnuts
Lugnuts
This question is so basic im not sure if i should even post it....
I just noticed my front left tire has a lug nut missing, and the screw is mildly rusted, I think that a small chuck of the screw corroded off.
Anyways, I have 4/5 lugnuts on that tire right now.
1. Is this safe for the time being?
2. Can I buy one lugnut that somewhat matches? Or am I going to buy 20 to match em up?
No. The studs, which the lug nut is screwed onto to hold the wheel to the hub. You can hit then out with a hammer. you will have to remove your rotor. I once snapped a stud, being stupid. You might have to heat them a bit, but don't go crazy with heat. I would relace the lug with a stock one from the dealer. If you don't have stock lugs and can't find a match, then spend the extra money and replace all of them. Better to have one size than many different sizes.
when i replace the studs, i take the hub off and use a big bench vice that can open the jaws 5 - 6 inches. i use a large size socket that will fit over the back side (non threaded) of the lug (maybe 30 mm or 1 1/4 inch) and put the socket and rotor into the vice so i have to jaws of the vice touching the socket and the threaded end of the stud and close the jaws of the vice. the vice then acts like a press.
to put a new stud in, i just lube the hole in the hub and use a flat sided nut and screw it in.
hokiemax
Sep 17, 2004 07:45 AM
spirilis
38
Sep 9, 2004 08:36 PM
maximalnemisis
Sep 6, 2004 10:53 AM
