Noise In Engine Bay?
Old Jul 19, 2005 | 07:46 AM
JetBlackMax83's Avatar
Hey I have a rattling coming from what it sounds like the right wheel well. When I hit the gas around 1G to 1.5 RPM it sounds like its coming from the some where around the belts or swing arm but im not certain since its only makes the sound well im driving and when i first hit the gas in 1st gear any idea's guys?
Old Jul 19, 2005 | 09:33 AM
HondaKiller718's Avatar
check your belts and make sure none are loose or not seated properly. Also park your car, turn it on and pull on the throttle wire to see if you hear the noise. if its only while you are driving then check your around your right front wheel, does it make noise when you turn?
Old Jul 19, 2005 | 11:14 AM
makes the noise only when im moving and around 1st gear in the low rpms its like a metalic rattling sound
Old Jul 20, 2005 | 08:50 AM
bump 12345
Bonka
Sep 14, 2015 11:18 PM
seesole
Sep 14, 2015 12:38 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
jfl330
Sep 4, 2015 01:44 PM
