Loud SQUEAK during start up
Old Jul 21, 2005 | 03:45 AM
Iron Scimitar's Avatar
Tha Snatcher
I've had the problem for about a few weeks. This happens when i start the car up in the mornings to leave for work. I turn the ignition and a loud SQUEAK happens. Its funny cuz the sound stops when the oil light on the dash fades away after start up. Is it somehow related? i'm about only 200mi over an oil change. Could it be my spark plugs? They are relatively new. Im currently running NGK Coppers.
Old Jul 21, 2005 | 04:00 AM
Jatan's Avatar
Could be the starter noise: http://www.motorvate.ca/mvp.php/516
Could be a belt...
Old Jul 21, 2005 | 04:13 AM
Tha Snatcher
Could be a belt...
Nice write up, but i have this problem in addtion to the loud squeak. i guess it could be a belt. I hope it is. My car sounds like bloody murder when it starts up.
Old Jul 21, 2005 | 04:51 AM
joesmith's Avatar
The starter noise does not sound like a squeak. When was the last time the belts was replaced?
Old Jul 21, 2005 | 04:55 AM
Tha Snatcher
The drive belt was replace back in May. The other one hasn't been touched yet. You think that's the problem?
Old Jul 21, 2005 | 05:13 AM
4thgenx42's Avatar
I have the exact same as im typing this. It is your drive belt. On my car it happens because i need to replace my belt tensioner. Have a look at the belt and check for their conditions. If not take a look at the tensioner as the belts might need some tensioning.
Old Jul 21, 2005 | 05:25 AM
Tha Snatcher
Awesome, thanks!
Old Jul 21, 2005 | 05:58 AM
joesmith's Avatar
Belt can stretch over time. At proper tensioning, the belt should deflect about a quarter of a inch.
Old Jul 22, 2005 | 01:53 PM
bradt's Avatar
I had the same problem. Replaced the belt and squeek went away. When looking at the replaced belt after, it had the usual wear with some cracks on the interior of the belt but looked fine. Try tightening your belt.
Could it be the PS belt making the noise?
Old Feb 2, 2007 | 10:37 PM
kinesisfilms's Avatar
it is the drive belt i have the same problem its just my noise doesn't go away until i revthe hell out of my engine....my old drive belt was cracked...took it to nissan....they replaced it with a brand new one.....this is when the problems started with the noises.....i am going to be taking it back to ge checked out to see if it was put on too tight or too loose.
Old Feb 7, 2007 | 04:06 PM
frumundacheese's Avatar
noises
I think i have both the problems listed. The squeek comes occasionally and is more on the passenger side meaning most likely the belts. The almost a buzzing sound comes from the drivers side of the engine I believe, I'm assuming it's my starter not disengaging. Are my assumptions correct?
Old Feb 8, 2007 | 06:39 AM
maxprivate's Avatar
Black Lion
Could be a belt...
i have the vweee sound in the write up but my starter is only about three years old. the noise goes away once the car warms up.
Old Feb 8, 2007 | 08:23 AM
cardana24's Avatar
Blown
I think you need to tighten your belt a little bit. You should be able to turn it 90 degrees but no more with out major effort.
Old Feb 8, 2007 | 09:13 AM
maxprivate's Avatar
Black Lion
i dont know if you were refering to me or not. but i know mine is definetly not a belt noise. im a hvac tech and i deal with loose belts all the time. and belt noise unsually doesnt go awat untill you correct the problem wheter its loose or cracked.
Old Feb 8, 2007 | 10:50 AM
rjtiobol's Avatar
Had the same problem a week after shop changed the belt.
They tightened the belt and all is good.
Old Feb 8, 2007 | 11:39 AM
cardana24's Avatar
Blown
no, I was replying to the op....Kareeeeeeem
Old Feb 8, 2007 | 06:34 PM
Fr33way™'s Avatar
Wild for Width
Tensioner for the AC/ALT. Even if it is a brand new belt if it is not in spec your car will sound like an '88 Ford Taurus on startup.
Old Feb 8, 2007 | 07:36 PM
Gismo-T's Avatar
B!tch We Got a Problem
I don't think that it's your belts. You say that your about 200 mi over on a oil change! Well the same thing is happening to me in the morning upon start up, then stops after 30 sec. I'm also past due on a oil change, but once you change your oil that SQUEAK will be gone. No more squeal in teh morning!!!
Old Mar 2, 2007 | 06:30 AM
Concord's Avatar
Yeah...changing your oil will stop all engine squeaks
alahjahwan09
18
Sep 21, 2015 09:12 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
SusieQQ
Sep 9, 2015 12:14 PM
trungg86
Sep 4, 2015 04:58 AM
