What is this thing (Pic)
Old Aug 11, 2005 | 12:46 PM
lanky2882's Avatar
the thing that connects to the right rear of the manifold. when i had it off it looked dirty on the inside all black. How to clean it and what does it do?
Old Aug 11, 2005 | 12:48 PM
njmodi's Avatar
Do I get a tax break?
IACV - idle air control valve. Controls the engine idle speed during startup, etc.
(You are talking about the part with 3 connectors right?)
Old Aug 11, 2005 | 01:22 PM
lanky2882's Avatar
Ya would that being dirty cause the car to be really hard to turn over?
Old Aug 11, 2005 | 01:23 PM
njmodi's Avatar
It won't affect "turning over" as much as perhaps affecting how quickly the car catches - since when the throttle is closed, the only air is passed through the IACV.
Old Aug 11, 2005 | 02:02 PM
lanky2882's Avatar
Well what happens is i turn the key and it cranks and cranks and cranks until i pump the gas and then it finally turns on and then i gotta rev it a bit to keep it goin
Old Aug 11, 2005 | 02:15 PM
hacim105's Avatar
You might need a new starter.
Old Aug 11, 2005 | 03:18 PM
lanky2882's Avatar
Starter was replaced 5k miles ago and just started to happen. The engine cranks really good just dont light the gas. as soon as i start pumpin the peddle it turns on
Old Aug 11, 2005 | 03:58 PM
i30ds's Avatar
Armed and Dangerous
Fuel pressure problem. Probably the pump malfunctioning. Spray a bunch of starting fluid (or even carb & choke cleaner) in the tb, then put the intake back on and then try to start it. If it fires right up, you know you have a fuel issue.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
wingnut2006
Sep 19, 2015 06:13 AM
2kmaximel
Sep 16, 2015 03:19 PM
