1995 Mass Air Flow
Old Aug 12, 2005 | 09:22 PM
JClaw's Avatar
1995 Mass Air Flow
Has anyone had a 95 MAF go bad on them? My car hesistates/surges when I floor it quickly. The same symptoms are said to happen for 00+ mafs but I'm wondering if the same can happen to 95-99 MAFs.
Old Aug 13, 2005 | 06:20 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
disconnect your MAF sensor, and see if the problem is still there. The ecm will use the TPS and o2 sensor to determine how much air is comming through.
Old Aug 13, 2005 | 09:03 AM
Robski's Avatar
My 98 does the same thing. I replaced MAF, Plugs, Fuel filter, air filter, PCV and belts.
It will run perfect and fast for 30mins, then I get surges and the car seems to loose its pull power. Almost as if I am trying to drive with the ebrake on.
Any ideas?
Old Aug 13, 2005 | 09:13 AM
I30tMikeD's Avatar
Car will not drive with the MAF disconnected.
Old Aug 13, 2005 | 09:17 AM
DAVE Sz's Avatar
Hooooooonda.....
^ It will, it just won't really accelerate or go above 1800rpm. You can step on the gas all the way and he car will barely move.
Old Aug 13, 2005 | 09:49 AM
I30tMikeD's Avatar
I guess if you call that driving...
Old Aug 13, 2005 | 09:59 AM
DAVE Sz's Avatar
Hooooooonda.....
No, I don't but I'm sure some could interpret what you said as the car not running at all.
Old Aug 13, 2005 | 10:34 AM
AirMax95's Avatar
Yeah...my MAF went on me about four months ago like a previous post said, it would run fine until the engine warmed up then it would start hesitating and stuff. Sometimes it would cause the engine to idle inconsistantly and shut off. It's fixed now, but I can't remeber how much I paid. LOL. GL
Old Aug 13, 2005 | 10:44 AM
JClaw's Avatar
I think Dave B sells brand new maxima MAFs for cheap, but I don't know if he has 95-99 MAFs.
Old Aug 13, 2005 | 11:02 AM
s0ber's Avatar
You cant drive with the MAF disconnected, at least I cant, if I rev it it will just die
Old Aug 13, 2005 | 11:13 AM
udienow's Avatar
Yeah my MAF disconnected, the whole thing that is, clamp wasnt on tight at all. Car would idle very low and then die, and when floored it would hardly accelerate at all, put MAF back on and car was perfect again. (Had me worried for a few mins)
Old Aug 13, 2005 | 12:17 PM
DAVE Sz's Avatar
Hooooooonda.....
Right, why would Dave B be selling MAFs?
Old Aug 13, 2005 | 02:39 PM
killcrap's Avatar
i can drive mine for some reason.
Old Aug 14, 2005 | 01:05 PM
JClaw's Avatar
Unless I'm hallucinating, DAVEB does sell new MAFs:
http://forums.maxima.org/showthread.php?t=328330
Also, could a bad MAF cause the car to run lean? Or affect A/F in any way.
Old Aug 14, 2005 | 01:56 PM
DAVE Sz's Avatar
Hooooooonda.....
DAVEB does, Dave B doesn't.
Old Aug 14, 2005 | 01:58 PM
Kevlo911's Avatar
Kevlo for President
Get a used one, www.car-part.com
Old Aug 14, 2005 | 02:00 PM
JClaw's Avatar
Yes, I'll get a used one if I can't get a new one for cheap, but new would be better.
Old Aug 14, 2005 | 02:07 PM
Kevlo911's Avatar
Kevlo for President
366.14 New...
Old Aug 14, 2005 | 02:44 PM
s0ber's Avatar
I got mine for $50 from car-part a few years ago.
Old Aug 14, 2005 | 02:47 PM
JClaw's Avatar
Did it solve the problem for you?
Old Aug 14, 2005 | 05:48 PM
Garrick's Avatar
What does that mean when the car does that? My Maxima does it. I think they all do because my 95' and 93' Maxima does that. I learned to accept my "Turbo-lag."
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
