engine flooding real bad after installing 6 new injectors?????
Old Aug 22, 2005 | 01:25 PM
bendy's Avatar
Why is my Maxima flooding after installing new injectors.
Old Aug 22, 2005 | 01:26 PM
NmexMAX's Avatar
dot dot dot ...
They probably aren't set right, you may need to go back and recheck all the o-rings/gaskets and see what kind of seal you're getting.
How do you know it's "flooding"?
How many did you change?
Old Aug 22, 2005 | 01:31 PM
Jeff92se's Avatar
I'm needing a caw
Thread title says "after replacing all 6 injectors".
Old Aug 22, 2005 | 01:36 PM
PTownMax's Avatar
I still miss the max
got a fuel pressure regulator to go with the injectors?
what kind and size are they?
Old Aug 22, 2005 | 01:38 PM
NmexMAX's Avatar
dot dot dot ...
I don't read titles
Why did you change all 6 ...
Old Aug 22, 2005 | 01:42 PM
Jeff92se's Avatar
I'm needing a caw
Who knows. But carefull about replying. If you don't hand this guy answers on a platter, he hits up your rep as negative.
I don't read titles
Old Aug 22, 2005 | 01:50 PM
bendy's Avatar
I replaced all six just to make sure they were all working the same. I used rebuilt pythons, wich were supposed to be the same as the factoryn ones. I've never checked the fuel pressure regulator.
Old Aug 22, 2005 | 01:52 PM
bendy's Avatar
I got only 45 miles out of half a tank. the exaust blows lots of white smoke which smells like gas. The car runs like it's misfiring real bad at all speeds.
Old Aug 22, 2005 | 01:54 PM
matty's Avatar
either take it back apart and check that all the O-Rings are seated properly..its sounds to me like the O-rings on the injectors arent seated properly or missing
If you dont want to take it all back apart, bring it to a macanic or nissan and have them look at it..
-matt
Old Aug 22, 2005 | 01:57 PM
NmexMAX's Avatar
dot dot dot ...
Any codes to go with this ...
Old Aug 22, 2005 | 01:58 PM
Jeff92se's Avatar
I'm needing a caw
I'll be nice. I can guarantee you didn't install the 0-rings correctly. Or used the old ones. You got gas flowing around the injectors and into the engine.
http://www1.autozone.com/servlet/UiB...3d801f5140.jsp
Old Aug 22, 2005 | 02:06 PM
bendy's Avatar
multiple misfire at first, I cleared it and haven't seen it again
Old Aug 22, 2005 | 02:07 PM
bendy's Avatar
when i changed the plugs, 1 &3 were soaked with gas
Old Aug 22, 2005 | 02:08 PM
matty's Avatar
Start taking it all back apart...order Nissan O-rings...Make sure you put some oil on the O-rings before you push the injectors back into the fuel rail
-matt
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
Ray229Harris
Sep 16, 2015 08:16 PM
Balkins
Aug 12, 2015 06:39 AM
