99 maxima need help on wheel problem!!!!!!!
Old Aug 28, 2005 | 04:55 PM
funmax's Avatar
The steering wheel of my car start to shake when i get to 60mph, i've done the alignment and wheel balance but it doesn't help. Someone told me that i may need to change the wheel bearing. Anyone here got the same problem. appreciate your help
thanks
Old Aug 28, 2005 | 05:25 PM
Stuntin' 101's Avatar
first thing, make sure that the front wheels balance out to "0", and that there isnt a slight bend in one or more. some places will not even tell you if there is. more than likely, if it was a wheel bearing there would be a noise associated with it. if not, the trend seems to be either ball joints, control arm bushings, or tie rods. you are not the only one with this problem. i just ordered new control arms, that come with all new bushings and ball joints already installed, inner and outter tie rods, and front stabalizer links with new bushing from world suspension off of ebay for $235. considering thats about how much "1" control arm costs from nissan, its a very good deal. nick also has a very detailed write up with pictures on his cardomian site for the intall if you like to do your own work. personally, ill be having my mechanic do the install.
Old Aug 28, 2005 | 06:07 PM
joosdawg's Avatar
well said id also suggest if you have junkyer tires that you check for dips and wierd looking tread to make sure the steel belting is not broken. those dang uniroyals love to do that lol -Ryan
Old Aug 28, 2005 | 06:55 PM
lewtion1's Avatar
did you try switching around the tires to see if the feeling moves or gets better or worse. if you move the front tires to the back, see if the problem "feels" better. If so, then it is probably one of those tires. If it stays the same, then at least you concluded that it's not your actual tires/wheels.
Lakersallday24
Nov 7, 2024 07:31 PM
trasmadean
Feb 1, 2017 08:20 PM
morteljc
Wheels/Tires
Oct 22, 2015 08:43 PM
jomax14
Aug 12, 2015 11:49 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
