Camshaft position dying max wont start
Old Aug 30, 2005 | 05:18 AM
nismomax98's Avatar
Well last for the last week or so ive been having trouble starting the max, like in the morning or after it gets cold. It would crank but not start until maybe like 2 min of trying it would finally start, well yesterday it just would not start dead, WTF. So i run some codes of the ECU and get 0101 and 0403 camshaft sensor and TPS sensor. After that i unplugged the sensors and tried again it started, but im scared to dirve it because i dont want it to crap out completly and have to tow it home. Where can i get those two sensors and some part numbers would be great. Anyone have this happen to them.
Old Aug 30, 2005 | 07:34 AM
laylow1988's Avatar
going threw your troubles too. i have to crank it and at the same time step on the gas slowly snd it will start but if i don't step on the gas while cranking it will just spin the starter and not crank up. i'm still diagnosing my car but the answer to your question is here
http://www.trademotion.com/partlocat...97&catalogid=1
i called local dealers and the local dealers are like $20 higher than these guys .
also on that link check for crankshaft position sensor, it might be that too
Old Aug 30, 2005 | 08:10 AM
nismomax98's Avatar
thanx laylow i got a TPS code also but i changed it like 20k ago so im not sure thats part of the problem aslo
Old Aug 30, 2005 | 08:22 AM
njmodi's Avatar
Do I get a tax break?
Call Dan Tech at www.midwaypartsteam.com. Start with replacing the Camshaft sensor first... make sure you get the right one. I believe the one is you need is in the timing chain cover, right near the idler pully tensioner.
iflexsteel
Sep 15, 2015 03:37 AM
Rage Maximus
Sep 3, 2015 12:26 PM
305head
Aug 26, 2015 09:03 PM
BobMax
Aug 15, 2015 12:35 PM
Balkins
Aug 12, 2015 06:39 AM
