Trunk leaks!! WTF??
Old Sep 18, 2005 | 07:15 PM
suicidalspd99
Trunk leaks!! WTF??
My trunk is leaking again. I know I did one time but I thoght it was the screws for my spoiler. I sealed them with clear silicone. It now is leaking again. I see no run marks from water and the trunk seal looks mint. I am clueless. If i fit in the trunk i'd climb in and have water sprayed on it, but that isn't happening. If anyone has any ideas, let me know. Thanx in advance.
Bill
Old Sep 18, 2005 | 07:17 PM
Black Maxima
I can fit in your trunk. I'm smaller than you.
Old Sep 18, 2005 | 07:28 PM
suicidalspd99
Good. Guess what your doing later this week.
Old Sep 18, 2005 | 07:44 PM
jjacob513's Avatar
yea have the same prob and its not the seals
Old Sep 18, 2005 | 07:48 PM
guyfromkop's Avatar
i had that problem, if you look at the gap between the quarter panel and the trunk, the check the welds, i had a pin size hole and it was leaking water like crazy, it was right above the lights, basically on the corner
Old Sep 18, 2005 | 08:27 PM
sunten1
You can fit me in the trunk too... Ill do it for you...
-edit btw to fix your sig... after the link change it to [/img]
Old Sep 18, 2005 | 08:32 PM
Sounbwoy's Avatar
If you have a sunroof, the drain tubes run to the trunk. If the tubes aren't placed in the drain holes, that could be it. Maybe also check to make sure your antenna assembly is secure...
Old Sep 19, 2005 | 05:22 AM
njmaxseltd's Avatar
The most common place for water to get into your trunk is through the tail lights. Especially if they have been removed and reinstalled on the car.
The trunk seal really isn't the seal for water, the channel around the trunk is there to guide the water out, right over the tail lights! Open the trunk and pour water down your rear window and watch exctly where it goes, out over the tail lights.
Go to the auto parts store and get a package of Dum Dum strips. Remove the tail lights and put a new strip of black Dum Dum over the old stuff. Reinstall the tail lights, pressing them firmly into place.
Old Sep 19, 2005 | 09:47 AM
suicidalspd99
Yeah i removed the tails to put the clears in . But I did seal it with new stripping. I really do need to fix it. One time before I took the plug in the btm out. The sparetire well was 5 inches deep. Also to let you know I don't have a sunroof. Thanks everyone.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
