0409 (rear bank 02 sensor) code keeps coming back :(
Old Sep 19, 2005 | 07:25 PM
erty67's Avatar
Decal Specialist
OK, I for the good ol' CEL a few weeks back and it gave me the 0409 can 0304 codes. I've since changed both the rear bank o2 sensor and the knock sensor. The 0304 (knock sensor) code hasn't come back, but the 0409 code would stop showing up. Any ideas why this may keep coming back??? Also, this seems to have started shortly after my alternator died. Coincidence or cause? HELP!!
Old Sep 19, 2005 | 09:57 PM
MDeezy's Avatar
Test the o2 sensors with a multimeter to verify that indeed the sensors are bad, if they arent that could be a good start right there.
Old Sep 20, 2005 | 05:11 AM
njmaxseltd's Avatar
0409 is the right bank (front of the car) upstream (before the cat) oxygen sensor.
Perhaps your looking at the wrong sensor.
Old Sep 20, 2005 | 06:34 AM
erty67's Avatar
Decal Specialist
The right bank is the the one on the back side of the engine bay, before the cat. I think I have the right one.
MDeezy...I have a volt/ohm meter. Just tell me how to test them.
Old Sep 20, 2005 | 07:06 AM
MDeezy's Avatar
njmaxseltd is right the right back is the front of the car the o2 sensor closest to the front of the car.
Right bank is cylinders 2,4,6 which is at the front
Left Bank is cylinders 1,3,5, closer to the firewall.
I looked up 0409 and its undefined. As for testing I'll have to post later the numbers you'll need to check for, dont have my haynes with me at work.
Old Sep 20, 2005 | 07:58 AM
Stephen Max's Avatar
Cylinder numbering is correct, but the right bank is the one closest to the firewall.
Old Sep 20, 2005 | 09:05 AM
MDeezy's Avatar
SHiit, then I just ordered the wrong o2 sensor. . .
Old Sep 20, 2005 | 09:10 AM
Just cut the harness off the old one and solder it to the new sensor.
Old Sep 20, 2005 | 09:11 AM
MDeezy's Avatar
I'll do that if he's shipped already, bought off an org member and are going to ship this afternoon, so hopefully he comes on before then.
Old Sep 20, 2005 | 09:28 AM
njmodi's Avatar
Do I get a tax break?
Actually the 2 front sensors are identical, except for harness length. If you look at www.oxygensensors.com, they sell you the same sensor and harness (since the harness length difference is marginal) for both front spots.
So you should be fine using the one you bought for either the RH or LH bank.
Old Sep 20, 2005 | 09:31 AM
MDeezy's Avatar
Thanks for that info I was scratching my head yesterday wondering if the front two were really different or not.
Lakersallday24
Nov 7, 2024 07:31 PM
fastcarny
May 18, 2020 10:40 AM
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
