'98 foglights?
Old Sep 21, 2005 | 03:06 PM
R5a7B's Avatar
'98 foglights?
Does anybody know how to replace the foglights on a 98? i have a new set of high performance ones, and i would like to know how to get in there and replace.
-Jim
Old Sep 21, 2005 | 08:42 PM
96blackmaxSE's Avatar
boost me.....
can i buy ur old onessssS?
Old Sep 21, 2005 | 08:43 PM
boost me.....
PM me if ur interested..............
Old Sep 21, 2005 | 10:40 PM
RicoSuave98's Avatar
hey man its very simple. the little black thing next to the fog light comes out and reveals 2 bolts. they have a phillips head but its best to use a 10mm wrench. soon as you get the bolts out the they pull right out. there is a bracket inside that supports the fog light. if you want to totally get rid of them, you need to take off the bumper cover to get to them. adn gettin the bumper cover off is quite a pain in the ***.
if you remove the stock ones you should be able to tap into the stock wiring, pending your electrical skills, and make them run off your stock switch.
hope that helps
Old Sep 22, 2005 | 04:20 PM
R5a7B's Avatar
Thank you very much, im just talking about switching out the actual lights, but it is very helpful, get rid of the lil black thing (possibly with flathead or is it easier than that?) and i can just switch em off?
-Jim
Old Sep 24, 2005 | 03:53 PM
aussie983's Avatar
-Jim
Yes all you gotta do is take out that one screw and the black piece will come off. 2 screws hold in each fog and you unscrew them and unplug the harness to take them off. You can just pull out the fuse or something if you're using separate wiring for the aftermarket ones.
Old Sep 24, 2005 | 08:49 PM
R5a7B's Avatar
Thank you all very much, i shall post a pic soon... and does anyone know how to get rid of the milky glaze sort of thing on the lights? (the outer parts)
-Jim
Old Sep 26, 2005 | 09:36 PM
aussie983's Avatar
You can't since theyre made from glass and no amount of polishing or rubbing compound will help (at least theyre glass on the 97s). Ive already tried with novus and it doesnt do anything. That kinda stuff only works on plastic.
Old Oct 5, 2005 | 08:02 AM
impliedparadox's Avatar
What do you mean by "high performance"? I am putting in PIAA Xtremewhite Pluses in mine as soon as they come in.
Old Oct 5, 2005 | 09:22 AM
R5a7B's Avatar
PIAA Star White 3800K
Old Oct 5, 2005 | 10:29 AM
NCSU_MAX's Avatar
Maximoneypit
ceasar did a great little write-up
http://forums.maxima.org/showthread.php?t=398546
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
fc95se
Nov 15, 2000 05:14 AM
