OK Im confused...
OK Im confused...
I changed my fuel filter today. Now my car won't even try to start... Here's the story: I pulled the fuel pump fuse before and crank the engine a couple of times to get the fuel pressure down. Changed the filter, put everything back together, fuses back to where they belong, started the car and everything was fine. I drove it around the block and everything worked fine. I started it a couple times and went back inside. 4 hours later I go to start it and nothing. Things turn on in the cabin, and when I go to start it you can hear the click in the fuse box, but the car doesn't even try to turn over. Could this be my starter? I am really confused as to why this happened.
If you hear the click but no cranking, then your ignition switch is probably fine and your starter is dead. Give the starter a whack and see if it starts.
It may also be worthwhile to try and jumpstart the car... sometimes a dead/weak battery will have enough strength to engage the solenoid, but turn over the engine.
well as Im looking around there I notice a vacuum hose that attaches to nothing. It starts just below the starter on the transmission, snakes up by the MAP/BARO sensor and all those vacuum lines, and comes up by the larger hose that goes from the front valve cover to the mid resonator. And the way the hose curves it ends up resting against the resonator. What is this thing and is it supposed to be hooked up to anything?
Originally Posted by sean05
is it a 5 speed? if so just push the thing and pop the clutch while its in gear. it will start. had to do it the other day.
Ok its the starter, thanks guys. Didn't think i could motivate this car with a hammer, with all its computers and sensors and everything. But you learn something new every day
Kingmoe738
04-20-2014 09:29 PM
viking89
04-08-2013 05:07 PM
2001M20
12-19-2012 04:21 PM
getflushed
06-27-2011 08:25 PM
