Would anything trip a MAF code?
Old Sep 28, 2005 | 05:05 PM
MDeezy's Avatar
Woluld Anything trip a MAF code?
Typically with a bad maf you usually cant rev over 2.5K correct? I definately can rev far over 2.5K. Would anything fake a Maf code? I also have a IAT code (0401) and o2 (0308) code.
Just want to check before I got purchasing parts that I wont really need.
Old Sep 28, 2005 | 05:57 PM
njmodi's Avatar
Do I get a tax break?
Not that I'm aware of. Does it come back when you reset the ECU?
Old Sep 28, 2005 | 06:10 PM
MDeezy's Avatar
originally I just had an o2 sensor code. On my way home today I figured I'd stop in at advanced auto parts and get a free scan before I go home and change out the o2 sensor just so I know thats the only problem I have.
now I have:
0102-MAF
0308-unable to obtain Closed loop.
0401-IAT sensor
My codes are changing each time I check. I had o2 sensor but it was 0303 at first (Front Left Heated O2 sensor) now I have 0308 - closed loop control. I think I just clogged up my o2 when I poped the clutch to get my car to start that one time, I will try a reset and taking out the old o2 sensor and trying to clean it out/blowing it out maybe that will restore it.
Wont replace maf or IAT till I know their bad.
Old Sep 28, 2005 | 07:17 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
you don't have anything to monitor the maf voltage do you?
I know that when mine crapped out a couple of weeks ago, it was giving me funny readings on my safc. see if you can hook a multimeter up to the signal wire and rev it. that should get you a fairly good reading.
Old Sep 28, 2005 | 07:20 PM
MDeezy's Avatar
Nah dont have a monitor yet, will get my brother to rev while I check for voltage.
I dont feel signs of a bad maf, but that doesnt mean it cant still be bad.
Old Sep 28, 2005 | 07:25 PM
slimer's Avatar
mine was from a shady character, so I should have known. Have you had any quirky driving habits as of late?
Old Sep 28, 2005 | 08:37 PM
MDeezy's Avatar
same normal driving habbits nothing changed.
The only time I can think, I did try starting the car after putting in my starter (about 1 1/2 weeks ago) and I tried starting without the starter and I think the IAT sensor plugged in, car wouldnt start but tried desperately to crank. I went under the hood and saw they werent plugged in. Plugged in, cranked the car and all was fine. I just remember that moment, but the sensors being unplugged couldnt cause them to go bad. . . there not even plugged in!
I will check it out more tommorow after work.
Old Sep 28, 2005 | 09:14 PM
siballiance's Avatar
all i know Smilers maxima is the sheiat .
i like it
Old Sep 28, 2005 | 09:18 PM
MDeezy's Avatar
get a room
j/k
Old Sep 29, 2005 | 12:07 AM
blazingchimp's Avatar
i pulled a MAF sensor code when I had a huge leak when starting up my car after the 00vi install. fixed the leak, reset my ecu, and it hasnt come back.
Old Sep 29, 2005 | 06:53 AM
MDeezy's Avatar
I think its being tripped as a result of something else, when I get off I'm going to check the maf, put a new o2 sensor in, reset the ecu and see what comes back.
Because it certainly doesnt feel like I have a bad maf, but I'll find out.
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
