what would it take to get a max in the 10s?
Originally Posted by eckohb
actually, a 5th gen with the VQ35 reached 11.99 on slicks. I wouldnt make it up
Originally Posted by nissandrvr2004
cobra engine and RWD
why would u ever need the max in the 10s? if you want to get in the 10s you'll have to make it a TRACK car. not a car you drive to work. and if your makin a track car i hope its not with a 4 door sedan.
i would be happy with the max in the mid 12s. what else do you need from a daily driven car? just my .2$ on the topic.
ok, so on www.vqpower.com, was the website lying when it gave props to the guy making to 11.99 on slicks? He had previously run low low 12s, and finally inched into the 11s. If the site was lying, then Im lying.
http://www.vqpower.com/v2/modules.ph...rticle&sid=132
I was mistaken, it broke 12s, not 11s. I hadnt seen the link in awhile. My apologies
Originally Posted by SR-71 Blackbird
Umm, why don't you provide a more specific link? And yes, he's lying if he said he made low 12's without a turbo, S/C, or nitrous. It's PHYSICALLY FAWKING IMPOSSIBLE for a naturally aspirated maxima to reach low 12's.
Originally Posted by icedout
so in the long run it would take a whole **** load of hp and tq to get it in the 10s.Just got to have the $ and time to get it done.
but of course
Originally Posted by NmexMAX
My point was it's not all about a.s.s loads of power. If the power is used wisely, it can be made quicker than another car with more power, just not the same "set up", even though it has more power.
Originally Posted by NY 95 VQ30DE
buy a j30, swap in a 3.5, turbo the **** out of it, put it on the bottle. and presto. sleeper inifniti
Originally Posted by 2 Da Max
that car probably weighs like a boat
i dont even think that made sense..watever
I thought I might have a little insight as to how to get a 3200lb FWD car into the tens as it was just recently done with a Front Wheel Drive 3000GT. The memeber from 3si.org that did it has spent the better part of 18months working on this car and tuning it with 2 different set ups the current set up (Twin TD-05 Big 16G's) has been on the car for about 6 months. Heres a Vid of the first ever 10 second run in a FWD 3000GT http://www.3sforum.com/vids/10seconds.wmv
And here is a breakdown of his time slip:
60-1.920
330-5.007
1/8-7.408
MPH-107.46 holly CRAP that 's a crazy 1/8 MPH
1000-9.322
1/4-10.910 FIRST 10 second FWD 3S
MPH-142.15 Another 140+ MPH Run-New 3S trap record
The mod list he gave me is this:
Dont tell me i already know the cars are not the same but they are similar enough that this list could give a good idea of the kinds of mods it would take to get a max into the 10's
60-1.920
330-5.007
1/8-7.408
1000-9.322
Originally Posted by Import Power from 3si
93 3000GT SL
91 AWD 5 spd converted to FWD
SFR LSD insert
Fidanza Flywheel
ACT 6 puck
NA 2 bolt motor w/stock forged crank and rods and stock TT pistons
Sealed Power/Fed Mogul Rings and bearings
NA heads-mild port polish (done 2 years ago)
Stock upper and lower Plenum
Afertmarket (oem style) oil pump
Import Power Lightweight Crank Pulley
LINK Standalone
Profec B Spec II
Import Power Dual Pump Dual Feed Fuel system
Denso 720s
Import Power TD05 turbo kit
Knock off EVOIIIs
TT Radiator
Garrett Bar and Plate FMIC w/Import Power IC pipe kit
Greddy Type S BOV
MSD DIS-4 HO
OEM PTU and Coils
NGK non projected plugs R5671A-8 Gapped at 24
MSD Superconductor 8.5 wires
Auto Meter Gauges
Tech Edge WB
MT ET Streets on stock SL wheels
Powerslot rotors w/EBC green pads
KYB shocks w/ GCs
K&N Filter
Corbeau Forza and 5 point Cam lock harness belt
Momo steering wheel
Stock shift ****
22psi Radiator cap
Castrol Dyno oil 10W40
Penzoil Synchromesh
VP C16
SFR LSD insert
Fidanza Flywheel
ACT 6 puck
LINK Standalone
Profec B Spec II
Denso 720s
Knock off EVOIIIs
TT Radiator
Greddy Type S BOV
MSD DIS-4 HO
OEM PTU and Coils
Auto Meter Gauges
Tech Edge WB
KYB shocks w/ GCs
K&N Filter
Momo steering wheel
Stock shift ****
22psi Radiator cap
Penzoil Synchromesh
VP C16
Mardigra didnt respond yet? Why would you want 10 sec's in a max anyway? I'd be happy with 13's just to beat some srt4's and evo's. I'll never see that though cause I have an auto. Hopefully I'll hit 15.5 at the track on friday.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
