CV boot replacement
Old 10-01-2005, 06:16 PM
twiggy144's Avatar
CV boot replacement
Just did an oil and brake pads change, and I noticed the left side outer CV boot has a crack. There is still a lot of grease inside, the cv joint does not look damaged.
I want to replace the boot myself. I think I can take out the big 36 mm nut on the shaft, with a breaker bar and a cheater bar. I dont know how to install and tighten the special straps ( like giant hose clamps) that hold an seal the cv boot to the shaft. Motorvate.ca does not mention anything special about the straps.
Cant it be done without a special tool? Is it necessary to remove the whole cv shaft from the transmission, or can the new boot be installed while the shaft still in?( I have auto trans).
Thanks guys.
twiggy144 is offline
Old 10-01-2005, 10:10 PM
maxS
good luck exploring... and get a heavy hummer to knock the cv joint off the shaft.
Old 10-02-2005, 06:13 AM
KH3 by popular demand
maxgtr2000's Avatar
On motorvate.ca it mentions to use a regular flathead screwdriver to pry it off. Double chek the site, I was on there last night because my passenger side went last week
maxgtr2000 is offline
Old 10-02-2005, 07:05 AM
speed racer's Avatar
I think its just better to replace the whole shaft. You might not have noticable damage to the joint, but replacing the whole shaft is less messy you will have a new part.
speed racer is offline
Old 10-02-2005, 08:23 AM
djengr's Avatar
I agree. Remanuafactured from Autozone run in the range of $60 to $100 and they have a lifetime warranty, for what that is worth. By the time you invest $30 dollars or so in the outer boot (you need to look at the inner boot at this time as well) and an extra hour or so getting the boot replaced you could have close to new installed.
djengr is offline
mvm062
11-30-2020 09:00 AM
PH98I30
26
10-12-2015 05:01 AM
dvcamp
09-18-2015 10:17 AM
Maxima30
09-07-2015 06:13 PM
TheMafia
09-04-2015 08:26 AM
Quick Reply: CV boot replacement
