corner light removal?
Old Oct 27, 2005 | 02:23 PM
TurTLe*'s Avatar
omg.. this is like the dumbest thing i wrote so far. I'm trying to install a set of headlights. I cant seem to remove the corner light the ones next to the headlights off. I see the top screw which was pretty obvious but its not coming off. So i assume there is a bottom screw as well. I cant locate this bottom screw at all. Been then a couple of FAQ's and stickies but non show how to really remove it.
Oh and also there suppose to be 2 bolts to remove headlights right. i saw the first screw which was pretty obvious. But again i cant find the 2nd one
Old Oct 27, 2005 | 02:40 PM
l3ftonm3's Avatar
yah its a pita to get it off. There is a part where a metal nub pops into, once you take of the first screw pull out the light as much as possile to give you some room then take a long flat head screw driver and look for the nub stick it in there and turn it to pop out the light.
Old Oct 27, 2005 | 02:41 PM
NCSU_MAX's Avatar
Maximoneypit
theres a couple screws for the headlight. for the corner light you just have to muscle it out once you get that screw out. it will come - just needs a little "positive" reinforcement.
Old Oct 27, 2005 | 02:42 PM
99SEL4ME's Avatar
The corner light has a ball and socket on the bottom. Just pull firmly but carefully from the bottom of the light, it'll pop out. When you re-install it, be sure to put the tab of the corner light behind the tab on the fender. The headlight screws, one is kind of far in, you just have to look. It's almost underneath the radiator support, if that's the one you can't find. Good luck!
Old Oct 27, 2005 | 02:45 PM
TurTLe*'s Avatar
i'm still muscling it right now. Its really a pain to get off. i feel like i'm gonna tear it apart or something. thanks guys i'll keep working on this
update_ well i broke the corner. Well not actually break. I can reinstall it normally. the ball joint thingy is never came off the connector but my corner came off. the plastic piece that goes to it snap off my corner. But now it makes installing and reinstalling a breeze :P
NOt that i think about it. this is such a stupid wierd design that nissan made. i dont see how it benefits.
Old Oct 27, 2005 | 03:08 PM
99SEL4ME's Avatar
If you're letting a little plastic cornerlight, kick your a$$, then you'd better start hittin' the gym. .................. Just kidding. Mine was tough the first time, a little tight, but the more you have to remove them, the easier it will get. Hmmmmm, I could have made a sexual inuendo there. Sorry, one track mind, much like MDeezy.
Old Oct 27, 2005 | 03:15 PM
TurTLe*'s Avatar
its not that it whooped my butt, its cause i didn't wanna break it. Well now i did and i guess i won that battle = P
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
dcardello
Sep 3, 2015 11:44 PM
