lsd or not??!
Old Nov 4, 2005 | 04:27 PM
jp_cout's Avatar
lsd or not??!
winter has started in here and i'm trying to figre if I have an lsd or not??!....I think that I have one because when I've done some burnouts this summer, the 2 wheels were spinning togheter...but is it enough to conclude that I have an lsd?
thanks!
Old Nov 4, 2005 | 04:28 PM
THEJEFFERATOR's Avatar
man, i miss the lsd days.....
Old Nov 4, 2005 | 06:21 PM
Northern Maxima's Avatar
I have a 99 ES and I have LSD so you must too. As far as I know, most Canadian Maximas have them.
Old Nov 4, 2005 | 06:51 PM
Tryonetic's Avatar
I have a 99 GLE with auto tranny, is it possible to swap for a lsd auto tranny?
Old Nov 4, 2005 | 07:16 PM
I'm no expert but as far as I know it is...
Old Nov 4, 2005 | 07:32 PM
Thorby's Avatar
What the hell [I]is lsd? Besides the drug, of course.
Old Nov 4, 2005 | 07:48 PM
Tatanko's Avatar
Bacon Lover
Limited slip differential
Old Nov 4, 2005 | 09:43 PM
TurTLe*'s Avatar
^ transfer equal power to both wheels instead of one spinning faster then the other. its kinda like traction control. more power is transfer to the slower spining wheel to make them go even. Great feature really.
Yea i'm not sure if they are directly fitted in our non-LSD auto trannys. I know you can drop them into the 5 speeds like nothing. And i assume you can put them into the autos as well.
Old Nov 5, 2005 | 07:44 AM
Tatanko's Avatar
Bacon Lover
You don't put them "in" the transmission. You swap the whole transmission. That's how most people go about doing it for the factory VLSD. Quaife and that cheapo fake LSD are a whole different situation, though. Good luck finding an auto LSD, too...they're pretty rare.
Old Nov 5, 2005 | 08:10 AM
Bobo's Avatar
I have a 95SE (Canadian model) and it has LSD. There have been numerous threads on this. I believe you can check a plate on the firewall and the numbering will tell you if someone can decipher it. For whatever reason, I don't have that plate but other local members do.
You can also jack the front end up and spin the wheels to check.
Alternatively, you can phone your local stealership and given them the VIN # and they can confirm whether or not it has LSD.
Old Nov 5, 2005 | 11:29 AM
Nealoc187's Avatar
SLOW
Check the plate on the firewall, passenger side of the car. If the transmission code ends in a V your car came from the factory with LSD, if it has an A it came with open differential.
You can't swap the VLSD into an open diff trans, but you can get the entire trans and swap it, not that it's worth it. There were LSD automatics made as well as manuals.
Old Nov 5, 2005 | 04:27 PM
I really like how my car handles in the snow. I think the LSD helps a lot with traction as there were a few times last winter I really should have been stuck because the snow was so deep, but I kept plowing through!
If you want an LSD tranny, I would suggest looking for one in Canada as they will be pretty common, either auto or 5-speed.
Old Nov 5, 2005 | 04:29 PM
kcryan's Avatar
LSD is a big no no, i once saw some dude go absoloutly nutz while on that stuff...
Sorry, had to say it after seeing the thread title
Old Nov 5, 2005 | 09:07 PM
highoctane79's Avatar
If you switch them do you have to change the axles as well or anything else?
Old Nov 5, 2005 | 11:23 PM
Nealoc187's Avatar
SLOW
If you are a 5spd manual and you go from open diff to LSD you have to change the driver's side axle to an LSD axle. If you are an automatic I don't know what all is involved.
ef9
Aug 14, 2015 03:03 PM
Supragte
Aug 12, 2015 10:00 PM
wolfmanjack210
Oct 6, 2001 05:15 AM
LoveSick
58
Jul 23, 2001 01:36 PM
Omegasrk
Nov 8, 2000 03:34 PM
