squeeky brakes!!! driving me nuts! ahhh!!!!
Old Nov 4, 2005 | 06:08 PM
evil_spork's Avatar
cliffs at bottom for the lazy/people like me who dont wanna read alot of junk.
so i was at the mechanic, ect ect, he has wheels off. i mention my brakes squeek, he says they are in fantastic shape.. like 85%. when i got it they were rated at 85% front 90% rear i think.. in that range, i dont think the number is relivant.
problem:
my brakes squeek like mad at low speeds. parking lot speeds and things like that make an awful, loud squeek. im so embarrased to have my car screaming like that. the mechanic said they are "good but are a bit glazed." now what the heck does that mean, and more importantly, how the heck do i fix it/the noise.
the brakes work fine, ive had a few times where i had to SLAM my brakes to avoid a crash/abrupt red light, both were from about 70mph and i stoped very well and in the case of the red light even locked the tires. both cases the braking was safe and all was well.
cliffs:
1. brakes squeek
2. they work fine(tested)
3. mechanic said they are glazed
4. what does it mean that they are glazed, and how do i fix that?(or do i?)
5. how do i remedy this awful sqeeking!
Old Nov 4, 2005 | 06:20 PM
pmohr's Avatar
No more Maximas...
Mine are the same way.
Well, I don't know about them being glazed over, but they sure squeak steadily at very slow speeds, and only at 1/2-3/4 application of the brake pedal. I've tried two or three different types of squeal compound, but none has worked so far.
I think I'm going to just douse everything in Brakleen and try one more time.
Old Nov 4, 2005 | 06:26 PM
evil_spork's Avatar
lol
weird..., we have the exact same problem. i dont recall it happening 5k miles ago. but it is now....... actually it seems to have started around my last oil change! weird.
Old Nov 4, 2005 | 06:32 PM
njmodi's Avatar
Do I get a tax break?
Both of you -
1. what pads?
2. were the rotors resurfaced when you replaced the pads?
3. did you use anti-squeal goop on the backs of the pads and the shims?
Old Nov 4, 2005 | 06:35 PM
MilesA's Avatar
The squealing sound is caused by a high-frequency vibration when a brake pad rubs against the brake rotor. You probably do not hear squealing when the pads are fully pressed against the rotor during hard braking. Only during light braking.
To avoid this, when the brake pads are installed:
-use new shims, the shims are thin, springy metal backing plates that fit between the caliper and the back of each brake pad
-coat the back of the pad with anti-squeal compound, this is a copper or polymer-based goop that will dry to a rubbery consistency. The compound absorbs vibration which prevents your pads from vibrating (and squealing). You can buy it from the auto parts store.
You can re-install your pads following these guidelines to quiet them down.
Old Nov 4, 2005 | 06:36 PM
evil_spork's Avatar
Originally Posted by njmodi
Both of you -
1. what pads?
1. stock(as far as i know)
2. i never replaced them. car only has 71k miles. i got it at 63k
3. i have no idea
Old Nov 4, 2005 | 06:38 PM
mjb95maxse's Avatar
when i got my car it had new pads on old rotors and it did the same thing(very embarrasing lol) i got new rotors and pads for under $100 and it was fine. spray new pads with brake cleaner when done oil or grease on them will make them squeek
Old Nov 4, 2005 | 06:40 PM
njmodi's Avatar
3. i have no idea
Then follow the advice MilesA provided - but you might want to take some fine sandpaper and take the shine (glaze) off the rotors (both sides). Don't sand too hard - just enough to rough them up slightly... use fine grit paper or emery cloth.
Old Nov 4, 2005 | 06:42 PM
evil_spork's Avatar
2000 grit sandpaper?
Old Nov 4, 2005 | 06:46 PM
njmodi's Avatar
sure - anything fine - like I said, you just want to take the shine off... don't want to introduce any indentations, etc. If you really want to be adventurous, you can just pop the rotors off and have them machined at Pepboys for 7 bucks each.... but if you're going to do that, you may as well do a complete brake job and replace the pads.
Old Nov 5, 2005 | 10:18 AM
ben99sel's Avatar
any suggestions for good pads for some spirited ( mostly normal) driving. I am looking for low noise and dust, are stock pads still the way to go?
Old Nov 5, 2005 | 10:24 AM
MilesA's Avatar
I'm using Akebono Pro-ACT brand which are very good quality ceramic pads, with the plain Brembo rotors. Very happy with this combination.
The OEM pads are pretty good, also.
Old Nov 5, 2005 | 10:25 AM
tomservo291's Avatar
i like my oem nissan pads + autozone rotors... no problems here
Old Nov 5, 2005 | 12:33 PM
Groundz's Avatar
Using Brembo Slotted on all for corners, with EBC green stuffs up front, and hawk HPS in the rear. When first installing the new brakes I followed the bedding in process and I never had any squealing or squeaking problems. As far as braking performance, there is virtually no fade under hard braking. Good combo IMHO.
Old Nov 12, 2005 | 12:53 PM
donald_duckk's Avatar
Put pad compound behind pads. Clean with Brake cleaner. If they are truely galzed you are jumping on you brakes to hard to often. Going down hills alot and hitting brakes on the way down. How do the rotors look?
Old Nov 12, 2005 | 01:05 PM
motocross416's Avatar
there are some pads that are called something like "acubono." That may not be teh correct spelling but its close to that. They are supposed to not squeak and have zero brake dust, but I believe they are about $80 for a set for the front brakes.
My rotors were sqeeking really bad, I was able to put in a new anti sqeak shims behind the pads and now they are perfectly silent. I think the shims were like $4 too.
Old Nov 12, 2005 | 02:40 PM
i30dvr's Avatar
problem:
cliffs:
1. brakes squeek
my was doing the same thing, mainly at low speeds, so i turned the rotors and scuffed the pads w/ sand paper to remove some glaze and it works great. Quiet!!!
lowpost99
Oct 26, 2025 06:53 PM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
crazyespn
Sep 3, 2015 01:30 PM
