Oil change question
Old Nov 12, 2005 | 02:15 PM
Cosmo459sx's Avatar
Oil change question
I'm sure you've all noticed the line covered in loom that is conveniently secured right underneath the oil filter. It is tucked right into that little bracket where the oil drips in when changing filter and dirt subsequently accumulates. I've tried to stuff a small rag in there when changing, but there should be an easier way, like re-routing the line in that area. Not really much of a service loop available. I'd be interested in hearing how creative others have solved this problem. Thanks in advance for any info.
Derek-
Old Nov 12, 2005 | 04:57 PM
ti2tmax's Avatar
Has his VINs memorized
I've just dealt with it as I believe that line is for your crankshaft position sensor for your crankshaft pulley. It also routes over to your Oil pressure sending unit.
Old Nov 12, 2005 | 06:41 PM
Cosmo459sx's Avatar
I didnt know that line included the crank pos, figured just oil press from what I could see. I guess I could deal with it. Maybe if I cut out the loom in that area, wrap the wires in good heat shrink, add some teflon protective tubing, then add another seal of heat shrink, and then reapply the loom.... but that is just too ****. I dunno
Old Nov 12, 2005 | 06:51 PM
ti2tmax's Avatar
I honostly think the wires are ok as long as there isn't any cuts or nicks there?
Old Nov 12, 2005 | 09:10 PM
Cosmo459sx's Avatar
I know, I'm just thinking long-term. It seems like a poor original engineering design.
Old Nov 12, 2005 | 09:11 PM
ryant35's Avatar
Spray it clean with some brake cleaner. Its what the shop I used to work at used to clean oil drips out from under the cars, if you don't the customer comes back thinking they are loosing oil.
Old Nov 12, 2005 | 09:24 PM
Cosmo459sx's Avatar
will do next time
kmitchel
Oct 30, 2016 05:28 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Johnny9595
Sep 3, 2015 05:18 AM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
