This sucks royally, and I again have to rip everything to get at my STS.
Originally Posted by jkmay01
wanted to know, what is the bolt size that should be used for the OEM application? I just got my hands on a Pacesetter sts from another org member. if the OEM bolt wont work what is the needed bolt size? let me know thanks
OEm should be okay, it may not be long enough. i dont remeber the size, your best bet would be to try and use the OEM bolt, if it doesnt work use that bolt as a reference and take it to a hardware store.
ok thanks !! will make sure to do that. i have a pacesetter sts that i got off of a org member, wanted to make sure there are no rubber bushings that are located on either side where the bolt connects to the shifter correct? i mean nothing big that should be cover the shifter's base from corrossion?
Derrick2k2SE
Nov 19, 2015 10:14 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
