diagnose ABS problems
Old Dec 2, 2005 | 11:06 AM
vettefever5's Avatar
my ABS and check engine light are both on. if i get the codes read for the CE light (i already know its rear o2 sensor) will it come up with any codes or anything for the ABS or do i have to bring it to a mechanic and have them diagnose it?
sometimes the light is on when i start the car, other times it comes on after ive been driving, sometimes not at all. its not a huge deal, i just want to try and get it figured out before snow starts falling and ABS would help
Old Dec 2, 2005 | 12:38 PM
GreenVQ30's Avatar
ya i was just gonna create a thread about this, my abs light is on too,
Old Dec 2, 2005 | 02:00 PM
JFP in PA
Ok Troops, here we go: Without the use of a Nissan Consult II or III, it is still possible to diagnose and ABS problem. It is one Hell of alot easier with the Consult because the ABS system is "protected code", meaning an OBD II scanner cannot access or reset it, but you can obtain the code and clear it by breifly driving the car over 20 MPH, then parking it and turning the ingnition off. You then attach a jumper wire from the Consult data link connector #4 (beside the fuse panel) to a suitable ground. After connecting the ground, turn the ignition to on (DO NOT TOUCH THE BRAKE PEDAL DURING THIS PROCEEDURE), and after 3 seconds the ABS MIL is start to blink out the malfuction code. Long blinks are "10's" and short blinks are "1's"; so three long blinks followed by two short ones is a code 32. The first code you will see will be a "12" which is the "self diagnostic start code" indicating that the process has begun. There may be more than one code as there are over 25 possible malfuction codes, starting (for unknown reasons) with the number 12 "start code". Once you have the code number(s), they can be cross referenced in a FSM for the correct diagnostic procedure to correct the fault.
After fixing the fault, the codes can be erased by starting the self diagnostic process above, but disconnect the ground jumper three or more times for a period of one second each within a 12.5 second time frame (no, I am not making this up). You will know that you have triggered the erase mode as the ABS light will stay on for a bit and then go off on its own.
I told you the Consult was easier...........................
Old Mar 29, 2007 | 08:38 AM
maxima985spd
So does the above directions need an OBDII scanner or not? it's not clear enough for me. Or can I just probe an actual wire from the pin on the plug to a ground and then the light will flash?
Old Mar 29, 2007 | 02:17 PM
Cdg2125's Avatar
this thread is 2 years old!
Old Mar 29, 2007 | 03:38 PM
maximacruizer's Avatar
pics? of what to attatch wire to
Old Mar 29, 2007 | 04:09 PM
maxima985spd
uhhhhh your point?
Old Mar 29, 2007 | 04:11 PM
maxima985spd
it's a plug behind the fuse door right below the steering wheel. I forget which point it is in the plug, but you can find it in the FSM.
bbsitum
Sep 6, 2019 07:31 PM
wingnut2006
Sep 19, 2015 06:13 AM
pears
Sep 18, 2015 05:25 AM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
