SP2 Leak...
Old Dec 2, 2005 | 12:50 PM
sean05's Avatar
SP2 Leak...
hey guys. well i just notice a small rumble comming from out of the flange behind the wheel on my exhaust. I grab a wrench and tighted it as tight as i could but it wouldnt get any tighter. what could cause the leak? if i get close to it i can hear it comming out of the flange. its getting on my nerves.
Old Dec 2, 2005 | 02:20 PM
lilaclucymaxima's Avatar
Team Ramrod
It's probably a gasket. Replace it.
Old Dec 2, 2005 | 03:14 PM
THT's Avatar
THT
Throbbing member
If you used the supplied gasket, I'm pretty sure that's your problem. I burned through mine after a year.
Old Dec 2, 2005 | 03:15 PM
RA030726's Avatar
I'm nutty for Nissans
remove the gasket and any remaining pieces and use permatex red to seal it up.
Old Dec 2, 2005 | 04:11 PM
86maxima96's Avatar
I Broke OT
didn't you just put that in there sean? i wouldn't think the gaskets would go that fast unless you used the stock ones.
Old Dec 2, 2005 | 10:21 PM
konak85's Avatar
quick question. just put on my cattman ss y pipe. Theres a kind of annoying rumble below 2300rpm while driving. Is this normal? I thought cattmans were almost stock.
Old Dec 3, 2005 | 12:42 PM
sean05's Avatar
ya i just got it a few months ago. i cant figure it out. it also hangs a tad low. i dont mind it hangin low but the rumble is pissing me off. where can i get permatex red?
is it possible to put it the gasket on backwards?
Old Dec 3, 2005 | 01:30 PM
Team Ramrod
Another alternative is buying gaskets from the dealer, they're cheap enough.
Old Dec 3, 2005 | 03:23 PM
Zach95SE's Avatar
My gasket there has blown out three times on my SP2 and I haven't had it a year yet.
Old Dec 3, 2005 | 03:43 PM
RA030726's Avatar
what types of gaskets are you all using?
Old Dec 3, 2005 | 03:47 PM
A Flood99's Avatar
OEM baby!!
Old Dec 3, 2005 | 04:18 PM
Team Ramrod
Genuine Nissan.
Old Dec 3, 2005 | 05:19 PM
chillin014's Avatar
i have a question about gaskets. sorta.
well i replaced my y pipe and where it connects to the cat the stock gasket was like 3 thin sheets of metal in the shape of the gasket i replaced it with which had a sort of papery texture and was thicker with a metal ring inside it.
well i had been getting this real high pitch rasp as high high rpm and i thought it was that gasket.
i went to autozone and the guy told me those thin sheet looking things was actually a spacer.....so i put that back in. the "BUDGET" gasket was burnt up.
i still have the rasp.
i dont feel like there is a good seal around any of my connections even with the gaskets in there.
so is the metal gasket really a spacer?
also, what are you guys doing about your sp2 burning your bumper at the tip of the exhaust?
Old Dec 3, 2005 | 05:31 PM
sean05's Avatar
are you using the permatex red? did you leave in the old gasket or no? i just want the annoy rasp to go away.
Old Dec 3, 2005 | 05:40 PM
chillin014's Avatar
same here.
i'm going to check out that sealant yall are talking about.
Old Dec 3, 2005 | 07:26 PM
Team Ramrod
Solution: weld it. I have all genuine nissan gaskets... cost me a bit more, but worth it. I have no raspy tone at high rpm's. As for your burning bumper... I have never heard of that in a '95-'96.
steven88
Sep 13, 2004 02:57 AM
nissanfreak
25
Jul 1, 2004 01:50 PM
billy_corgan
Jul 18, 2003 11:40 PM
nadir_s
Dec 13, 2002 09:04 PM
fatKID
Oct 1, 2001 08:50 AM
