Brake warning light
Old Dec 7, 2005 | 06:05 AM
a3gus's Avatar
Brake warning light
This morning after starting my max, the brake warning light (!) stayed on. Yesterday night I had a front flat tire so I used the emergency brake, but the light was off after that. The cable doesn't seams to be blocked... anyway my emergency brake works only at 5-10% of its capacity. I checked the brake liquid level and it's OK.
What could be the problem???
Any help would be apreciated. Thanks.
Old Dec 7, 2005 | 06:19 AM
C MAX's Avatar
usually it means your fluid is low or brake pads.
Old Dec 7, 2005 | 06:26 AM
njmaxseltd's Avatar
If the fluid level is ok (are you sure?) then it could possibly be the ebrake switch.
Is that the only warning light on?
Old Dec 7, 2005 | 07:35 AM
a3gus's Avatar
Is there a sensor on brake pads??? I never heard of that on 95 models.
Old Dec 7, 2005 | 07:37 AM
a3gus's Avatar
I'm sure on the fluid level, is at half between min and max. This is the only warning light on.
Old Dec 7, 2005 | 07:57 AM
a3gus's Avatar
Where is located the e-brake switch?
Old Dec 7, 2005 | 09:37 AM
ProjectMax96's Avatar
Ya brake came on the the other day and would come on and then go off. All i did was put some more fluid in and its fixed
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
