TS ecu is in: Not impressed.
Old Dec 10, 2005 | 03:43 PM
oTranscendental's Avatar
I don't know why, but I'm not feeling a big power difference. 15hp should be very noticable.
It has advanced timing and fuel maps. NO redline upgrade. Whats the deal?
I think I've heard that this might gain 10-15Whp. This cant be true.
Old Dec 10, 2005 | 04:11 PM
MDeezy's Avatar
. . . did they really reprogram it
Old Dec 10, 2005 | 04:33 PM
I just bought it from Maximaztion. This is the ecu I got from him with the daughter board in there. http://forums.maxima.org/showthread.php?t=442327
From what he told me this is a reprogrammed TS ECU.
Old Dec 10, 2005 | 04:35 PM
Kevlo911's Avatar
Kevlo for President
You SHOULD be able to feel an ECU. Only thing I can tell you is to dyno with stock ECU and this "TS" ecu to compare the numbers.
Old Dec 10, 2005 | 04:43 PM
Mishmosh's Avatar
It has to relearn partial throttle data, but WOT is where you should noticeably feel the difference right off the bat.
Old Dec 10, 2005 | 04:50 PM
MDeezy's Avatar
Maybe give the ecu some time to run thru its cycle. How long have you been driving on it and noticing no gains?
Old Dec 10, 2005 | 05:09 PM
deezo's Avatar
I noticed it in the acceleration while cruising.
Old Dec 10, 2005 | 06:29 PM
nismology's Avatar
Then it must've been the placebo effect since no changes are made below 40% throttle.
Now that i think about it, that entire statement seems to be a contradiction.
Old Dec 10, 2005 | 06:34 PM
nismology's Avatar
It doesn't matter how many driving cycles there are. The open-loop maps are the same whether you've just popped the ECU in or if it's been in for a few months.
Old Dec 10, 2005 | 06:42 PM
Jason R's Avatar
aka UNCDooD
I couldn't 'feel' my ecu all that well when I upgraded to a TS ecu. So, I took it to the track and compared it. The only other difference in my car was definitive motorsports UDP. I went from a 14.6 to a 14.25. Get a before and after dyno. that would be the best way to prove it.
Old Dec 10, 2005 | 09:37 PM
aussie983's Avatar
I could definitely feel it when i put it in. The tranny shifted much better and the torque seemed to be better all around and the power seemed to be much more linear. On the old ECU, it felt like i had no torque down low till i opened up the throttle and it got to higher RPMS. On the highway i noticed much better passing power.
Old Dec 10, 2005 | 10:29 PM
1FSTMAX's Avatar
i felt a difference with the Gforce ECU in my 97.. got 201whp with it in..
Old Dec 10, 2005 | 11:39 PM
Nealoc187's Avatar
SLOW
It's not as dramatic as a ypipe if that's what you are thinking.
Old Dec 11, 2005 | 01:05 AM
Ceasars Chariot's Avatar
Old Maxima Legend
neal he should be able to make two dyno runs right and see how the numbers work out ? i would do a dyno if I were you, the next time there is a dyno day around here, im going to take my stock ecu and ts ecu and do two runs and have a look at the numbers.
Old Dec 11, 2005 | 01:28 AM
I took it out for some more driving, and I did notice that the trany engages much smoother, and pulls in 3rd and 4th are much stronger than before. I can't tell in 1st and 2nd because there is so much snow and ice around. I still haven't gone to the highway, but I think it will be better. I am looking to dyno somewhere in Gaithersburg soon.
Old Dec 11, 2005 | 05:37 AM
I30tMikeD's Avatar
I don't know why the shifting on the tranny would feel any different.
There are most likely gains there, your just probably expecting too much. And if your trying to test it out in the snow and ice that could be part of the reason
Old Dec 11, 2005 | 10:03 AM
nismos14's Avatar
§è~® f®ÈÄk
I felt the difference right away when I put my TS in. It pulled VERY hard at WOT after 3300 rpm. Do you have any codes? KS ghost code maybe?
Old Dec 11, 2005 | 12:52 PM
I think I was just expecting a dramatic difference like when I got a ypipe, which was also a 15hp upgrade. But I feel it now, and its good. Its more noticeable in the higher gears (3,4,5) where I used to lack low end torque. But I NEED MORE POWA! Gotta save up 5gs for turbonium.
I think the tranny shifts better because the advanced timing revs slightly faster and therefor less bogging. I have a stage 2 clutch so..........
Old Dec 11, 2005 | 01:33 PM
NmexMAX's Avatar
dot dot dot ...
No dyno no care ...
Old Dec 11, 2005 | 01:34 PM
tomservo291's Avatar
Originally Posted by NmexMAX
No dyno no care ...
not everyone has the money, or a dyno right down the street to roll into every week ...
Old Dec 11, 2005 | 01:42 PM
NmexMAX's Avatar
dot dot dot ...
I don't either, but before I say this,
I'd make sure I'd havce a plot to back it up, before I start knocking on the product, and post a thread about it.
His car could have other issues.
Old Dec 11, 2005 | 03:26 PM
SMX95's Avatar
Thats the same ECU I wanted hell If you dont want it ill pay for 450 for it.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
jfl330
Sep 4, 2015 01:44 PM
