Intake?!??
Old Dec 19, 2005 | 12:01 AM
96nismomaxi's Avatar
.org window licker
Intake?!??
i just bought a new 99 max and i have been reading the forums about all of the aftermarket intakes and was wondering if there was an intake out there that dosent make u loose the low end that u want or one that is worth loosing a little bit of the low end??
Old Dec 19, 2005 | 12:32 AM
MorpheusZero's Avatar
Oh man, prepare to be flamed.
Read the FAQ section..
Old Dec 19, 2005 | 01:07 AM
gen4maxima536's Avatar
searching is always an option too
Old Dec 19, 2005 | 05:18 AM
njmaxseltd's Avatar
If you want some noise, get an intake.
If you want throttle response and performance, leave the stock intake alone.
Put a K&N filter in it if you want.
Old Dec 19, 2005 | 06:25 AM
GodFather's Avatar
Made in Taiwan
Brace yourself, what you've asked isn't going to get you an intake. It'll get your thread flamed by millions of torches. Good luck.
Old Dec 19, 2005 | 06:31 AM
NmexMAX's Avatar
dot dot dot ...
I vote Or at least
Old Dec 19, 2005 | 07:29 AM
lilaclucymaxima's Avatar
Team Ramrod
You obviously haven't read much then. Flame on.
Old Dec 19, 2005 | 07:37 AM
Iron Scimitar's Avatar
Tha Snatcher
1) No you have not been reading the forums...this thread proves that.
2) Yup, you're in luck. Its called the stock airbox AND its already installed in your car and ready to go!!!! Get a K&N drop in filter and call it a day.
Old Dec 19, 2005 | 07:55 AM
NmexMAX's Avatar
dot dot dot ...
We don't care how loose your low end is
Old Dec 19, 2005 | 08:37 AM
Tha Snatcher
Old Dec 19, 2005 | 08:57 AM
pmohr's Avatar
No more Maximas...
Originally Posted by Iron Scimitar
...I'm going to have nightmares after seeing that...
Old Dec 19, 2005 | 09:05 AM
NmexMAX's Avatar
dot dot dot ...
"Yeah that's not creepy at all. "
Old Dec 19, 2005 | 10:06 AM
devilz05's Avatar
Shift_3.0
And im personally offended with your Honda signature, hehe, but ill let it slide.
If you are willing to go through the hassle of making a heat shield, you will gain throaty sound with no expense to throttle response or low end torque. However, an intake during the humid summer days is a curse above all others. You will laugh, you will cry, you will kick yourself in the head for even considering it. During hot and cold days the performance of my car felt like a good 30hp difference.
Old Dec 19, 2005 | 10:49 AM
tavarish's Avatar
fwd gone rwd cr00
your knock sensor is bad, or you got an injen.
i have a hacked airbox, but i've heard the PR CAI and stock resonator work pretty well.
Old Dec 19, 2005 | 10:54 AM
devilz05's Avatar
Shift_3.0
I was referring to my civic, sorry. Lot less torque to go 'round, lol.
Old Dec 19, 2005 | 10:56 AM
tavarish's Avatar
fwd gone rwd cr00
wow, i would hate to have a 30hp loss on a civic, it would be tough to get up a hill.
:-D
Old Dec 19, 2005 | 10:57 AM
Maverick7687's Avatar
I have that JWT Pop charger that was put on by the previous owner so I dont know if it helps or hurts. I have nothing to compare it to.
Old Dec 19, 2005 | 11:04 AM
devilz05's Avatar
Shift_3.0
:-D
Please dont remind me! We have some wicked hills in suburbia, making driving in the winter straight up hazardess to your health. Anyways, on summer days I would be at 4kRPM before I would even start to feel the car accelerating on those hills. It brought tears to me eyes, lol. In the winter I avoid those roads like the plague. Have you ever tried to get into gear with two inches of snow on the ground, a car a foot behind you, and an incline like this dudes crown ? I honestly thought the end of my car was near. Fishtailing and sliding down hill....memories....memories....My friend has a 2000 Integra GSR 5spd and he had to leave it on the side of the road because he couldnt make it up the hill, his car just kept sliding all the way back to the start, LOL.
Old Dec 19, 2005 | 11:07 AM
Ceasars Chariot's Avatar
Old Maxima Legend
Maxima Intakes Explained
By Dave B of Maxima.org (not the parts guy)
1) The Frankencar Intake is just like the Stillen/JWT "POP"-style intakes except that the Frankencar/Berk intakes comes with a midpipe that replaces the OEM resonator that sits inbetween MAF sensor and throttle body. The Frankencar/Berk intakes have gotten the nickname "hybrid". A Stillen/JWT or any other POP setup can be converted to a hybrid by simply adding a midpipe. There is nothing remotely special about a Frankencar intake. Nothing.
2) A midpipe has yet to be documented to make any power gains, but it does introduce quite a bit more intake noise and a generally deeper sound. Most owners tend to like this induction noise under 1/2 to full throttle. The sound emmulates the sound of an Acura NSX.
3) The Injen intake is not a CAI. It pulls air from the drivers side front portion of the car just to the side of the raditor. IMO, this is probably the worst place to be drawing air. Also, the Injen piping is routed close to very hot engine components (manifold, head, block, tranny) which will heat soak the nice shiny intake piping.
4) The Cattman/Place Racing/Warpspeed CAIs are the only true CAIs on the market. These setups pull air from an area that is sealed off from the engine bay. These intakes pull in ambient air. These intake require cutting a 3.2" diameter hole near the battery to route the piping. Many owners are afraid to cut into their car for fear of resale problems. The truth is a good cut is not noticable because the hole sits in a location that is shielded by the battery and wiring harnesses.
5) The hacked airbox is when you cut out the lower airbox to bring in more air. This results in more sound, POP intake power, and the introduction of hot engine bay air.
6) The POP/hybrid/hacked airbox intakes are assumed to make better upper rpm power at the expense of lower rpm power. "Boggy" throttle response, especially in hot weather is common with these intakes. The lack of throttle response is most likely due to removing the pressurization effects of the stock intake tract and drawing in hot engine bay air.
7) The CAI intakes are assumed to make better lowend and mid rpm power. The CAI intakes don't seem to suffer from the "bogginess" problems because of the 14" longer intake tract which is able to store a column of air and in a sense keep the air pressurized, less turbulent, and cooler.
8) Dynos and track results have proven that all the intake setups POP/hybrid/Injen/CAI/hacked all perform basically the same assuming the air outside is cold and the engine is cooled off.
9) Hybrid/POP/hacked/Injen intakes pull in underhood air therefore in the summer these intakes can be drawing in air that's over 140 degrees. A CAI will be pulling in ambient air. It has been shown that the engine bay air cools down to near ambient once the car is moving at 30mph+ for a few minutes. The problem is the temp sensor and knock sensor typically will detect the extremely hot air coming in therefore from a stop the car's acceleration can feel weak in 1st gear. At the track this can cause a much slower 330' if the engine is not cooled.
10) In the end it comes down with what you're will to pay and what kind of driveability you want.
Old Dec 19, 2005 | 11:22 AM
lilmush's Avatar
Great post.
Old Dec 19, 2005 | 11:25 AM
NmexMAX's Avatar
dot dot dot ...
Stickys >* And they're getting to be quite outdated.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
