Help: Max wants to die when cold. hessitages during acceleration
Old Jan 5, 2006 | 11:07 PM
overseaz's Avatar
For the past 5 months my max has hesitated under acceleration but its getting worse. When your WOT sometimes its like half throttle to full throttle and back and forth.. Now i can even hear it backfire thru the intake or at least i think thats what the popping sounds are. (it only does that at highway speeds at WOT). If you drive around town like a grandma you may not notice the hessitation.. and it idles fine.
Then its also taken 4 or 5 tries to start it in the morning.
The past week, when you take it out on the road and slow down to a stop, the rpm's drop way low and it vibrates or totally dies out so i have to put it in neutral to avoid that. It only does this until it warms up then its just fine.
What would be causing some of this?
I've done allot of the maintainance recently.
New: spark plugs, oil/air/fuel filters, pcv valve. Cleaned: TB
No CEL light and No Codes either.
Some people have said maybe the Coil packs, Injectors or KS? What about the MAF or IACV?
Old Jan 6, 2006 | 01:16 AM
knuckles2's Avatar
I have a very similar problem but it is related to idle/RPMs dropping while either coming to a stop or at a red light, and this only occurs when it has been on the road for 25-30 minutes. So basically I am in danger of stalling out after 30 minutes of driving if I approach a stop sign/light. My max also seems to run very rich and gas efficiency has significantly decreased as it seems to waste a ton of gas. I had my starter replaced a short time ago, and had one of my fuel injectors replaced as well.
My local mechanic is also perplexed and cannot figure out what the problem is. Tried cleaning out TB /butterfly plate and condition is the same. The only code the mechanic is pulling is the KS code, no check engine light. My MAF and coil packs seem good. He also sprayed trottle cleaner everywhere around engine to test for vacuum leaks, dont know when I changed fuel filer.
I also notice that my battery has stuff all over the terminal cables so I am thinking replace the battery and fuel filter?
Anybody have any suggestions? I feel like torching my car........thanks in advance
Old Jan 6, 2006 | 01:22 AM
NmexMAX's Avatar
dot dot dot ...
How is this thread ..
Old Jan 6, 2006 | 02:22 AM
acidmeld's Avatar
sounds like your TPS is going, maybe your MAP sensor..
Old Jan 6, 2006 | 07:15 AM
maxgtr2000's Avatar
KH3 by popular demand
maf, pull codes to be sure, the ecu knows what's going on.
Old Jan 6, 2006 | 08:38 AM
s0ber's Avatar
10charrrrrrrrr
Old Jan 6, 2006 | 05:16 PM
wannabemechanic's Avatar
If you guys have a multimeter (fluke) you can always check the resistances of the coils and fuel injectors? Chiltons book has some common values if needed. Just an idea ? And you should clean the terminals of the batteries if you see oxidation occurring.
Old Jan 6, 2006 | 06:27 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
Today my car started for a little while, and then as I get ready to put it in first, it sputters and slowly whines to a stop. I tried giving it gas, but the car just sputters to a stop.
Old Jan 6, 2006 | 08:41 PM
overseaz's Avatar
Yeah i have a multimeter, I tested them once but i can test them again maybe can you email me or pm me the values from the chilton manual? When i tested them last time they all seemed to test out ok tho.
Dave
Old Jan 6, 2006 | 10:40 PM
s0ber's Avatar
Could be a crank sensor.
Old Jan 7, 2006 | 04:31 AM
gocel's Avatar
Hello, I had a similar stalling problem in a Maxima 1985 and it turned out to be a fuel pump problem. Thanks
Old Jan 7, 2006 | 08:22 AM
This also happened to me as well, I found out that i had to completely change the battery. I would get a jump and start the car, but when I put it into reverse the car would die. Check your battery first before anything, could be as easy as that? If not sorry.
Old Jan 7, 2006 | 08:24 AM
Dave
I'll get the values chilton has in the book when I get home, Sorry I dont have it with me at this time. I know its saturday a great day to work on your car sorry....but my car wont start either and i got fed up with it...but i'll start working on it later today or tomorrow ok....
Old Jan 7, 2006 | 10:10 AM
nismology's Avatar
Intake backfires indicate either a valve timing or ignition timing issue. If you can borrow a timing light from someone i'd use it to make sure timing is in check. Have you been hearing noises from the timing chain area?
Old Jan 8, 2006 | 08:30 AM
ignition coil
If you have a multimeter you can test your ignition coils. Remove your coil and read the resistance of terminal 1 and terminal 2. It should read around 0.8 ohms as stated in chiltons book.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
viperboy
Sep 27, 2015 07:05 PM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
