what kind of tranny fluid for 95 5spd?
Old Jan 20, 2006 | 10:09 AM
matts95max's Avatar
so im not sure on the type of transmission fluid to use? I have a 95 5spd and I know its dif. than what the auto's use. also what is the big dif. in batteries. like some are $50 and some are $150?
Old Jan 20, 2006 | 10:23 AM
tavarish's Avatar
fwd gone rwd cr00
use redline mt-90 GL-5 fluid for our trannies.
And batteries differ with quality, cold cranking amps, shelf life, and warranties.
Old Jan 20, 2006 | 11:57 AM
moogotzskillz2's Avatar
DO NOT USE GL-5! that will mess up the syncros. USE ONLY GL-4, adn MT-90 is good.... or any GL-4 product.
-moo
and on batteries. YELLOW TOP OPTIMA are reallygood.. but llik tavarish said they all differ.
Old Jan 20, 2006 | 11:58 AM
njmodi's Avatar
Do I get a tax break?
-moo
Old Jan 20, 2006 | 12:41 PM
DR-Max's Avatar
Been using Redline MT-90 for 3 years.....good stuff!
Old Jan 20, 2006 | 01:02 PM
s0ber's Avatar
Amsoil MTG 75w90 FTW.
Old Jan 20, 2006 | 02:27 PM
dgeesaman's Avatar
Maintenance Monster
-moo
Generally, stay away from the GL-5s unless it meets both GL-4 and GL-5 and it specifically states it's safe to not corrode sychronizers.
Redline MTL and MT90 are both true GL-4s, and Royal Purple, Amsoil, and Neo also make GL-4/GL-5s that are safe in our gearboxes. These are premium sythetics though and they will cost $50+ to fill your tranny.
But cheap off-the-shelf GL-5 is a mistake. If you're not getting something I listed above, it would be wise to buy something that says GL-4, period.
A battery is a battery, unless you are trying to save weight (which is silly since Max's aren't exactly Lotus's), or you are concerned with starting in very cold weather and long periods (days at a time) between starts. The extra cost goes into to addition CCA (Cold Cranking Amps) and a longer warranty.
Dave
Old Jan 20, 2006 | 08:38 PM
matts95max's Avatar
so just make sure it is gl-4..how much of it? also where do you fill it up at? like where do you pour the transmission fluid in? Thanks guys
Old Jan 20, 2006 | 08:45 PM
s0ber's Avatar
5 quarts.
Old Jan 20, 2006 | 08:47 PM
matts95max's Avatar
so can that be done with it in the car and everything hooked up?
Old Jan 21, 2006 | 10:31 AM
Bobo's Avatar
If you are asking these kinds of questions, just take your car to a lube joint and get them to do it for you. It's cheaper than an oil change. For my money, I stay away from the synthetic gear oil and just use GL4 in either a 75W90 or 80W90. I suspect an 80w90 is preferable in your state as it doesn't get that cold. 75W90 is better in colder weather.
Old Jan 21, 2006 | 03:11 PM
dgeesaman's Avatar
Maintenance Monster
But the "Lube Joint" is not likely to have anything but cheap GL-5 to fill with. They may BS you with the "5 is more than 4, so of course it will work" - which is wrong since cheap GL-5 is what does damage. So wherever you get it done, make sure it's a GL-4 of some sort.
Dave
Old Jan 21, 2006 | 04:15 PM
Bobo's Avatar
I am able to get GL4 at Mr. Lube in British Columbia.
magiconthetire
Oct 26, 2015 09:03 PM
fx4five
Oct 18, 2015 06:57 PM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
