I need help with a clutch problem!!! Help!
Old Jan 20, 2006 | 10:11 PM
ManualMaxima's Avatar
5th Gen till she dies!
Well for awhile my clucth has been acting really crappy. so today i decided to bleed it. me and my friend started to and i started pumping the pedal and nothing happened. The part that pushes in and out of the slave cylinder is not even moving. I tried replacing the slave cylinder and that did not work. We looked at my friends maxima and there is a "triangle shaped metal brack that holds the pin to the slave cylinder and it stays in and when you push the cluct in to comes out. That peice is not even moving. What could hiss be???
Old Jan 21, 2006 | 12:03 AM
nismos14's Avatar
§è~® f®ÈÄk
Check the fluid level, and it sounds like you have some damage to the hydraulics of the system.... which part
Old Jan 21, 2006 | 12:07 AM
Nismo's Avatar
Does the car drive?
Old Jan 21, 2006 | 06:06 AM
the fluis level is fine, when you try to bleed it barley anything will come out. The car cannot drive cause the clutch will not come up off the floor. You can start it but not get it into gear,
Old Jan 21, 2006 | 04:06 PM
bump
10 car
Old Jan 21, 2006 | 04:47 PM
Nismo's Avatar
how old/miles are on the clutch.
Old Jan 21, 2006 | 11:23 PM
car has 145,000 and the clucth has about 3000 miles on it
Old Jan 22, 2006 | 06:53 AM
nismos14's Avatar
§è~® f®ÈÄk
Sounds like that piece you described has a hydraulic switch or something that activates the slave and that is damaged, or the slave you bought was defective.
Old Jan 22, 2006 | 12:52 PM
dgeesaman's Avatar
Maintenance Monster
Sometimes a clutch that isn't bled properly will result in the clutch pedal stuck to the floor. You can pull it off the floor and continue trying to bleed it that way, but what worked for me was to use a vacuum pump to draw out the fluid/air at the slave end.
Dave
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
