Yes Ill take 2pc fried chicken, 1 ecu
Old Jan 30, 2006 | 10:16 AM
|Bijan|'s Avatar
UCF Lexus
Now Im almost certain Ive got a fried ECU
After a few hours of relentless "testing" sensors, fuses...etc here and there...
I told myself Im gona check codes for the hell of it (obd-II scanner) since it VERY WELL COULD be my crank sensor again.
Well, I turn the key to ACC and the CEL doesnt come on.
Is the bulb burned out? Maybe..
I try to read codes....and on the scanner it says
LINK ERROR
So, Ive already been looking at the ECU...seeing IF anything MAY have come loose, and it didnt look like it. I pressed firmly around the whole ECU just in case...
Now Im waiting on Jeff to ride over so I can swap ECUs to see if thats 100% the problem.
Will update later
Old Jan 30, 2006 | 10:28 AM
njmodi's Avatar
Do I get a tax break?
TTIWWU (updates)
Old Jan 31, 2006 | 06:52 AM
|Bijan|'s Avatar
UCF Lexus
No one has any further info on if OBD-II scanner reads - LINK ERROR and no CEL when turned to ACC position?
Old Jan 31, 2006 | 07:02 AM
s0ber's Avatar
In for later....
my CEL wont turn on if I turned the diag screw ont eh ecu and didnt turn it back to the non-diag position.
Old Jan 31, 2006 | 07:15 AM
mendon99's Avatar
tastey wheat
bijan if you cant find another ecu theres a technosquare one for sale in the 4th gen classifieds, 450 i believe. pretty good deal imo.
Old Jan 31, 2006 | 07:18 AM
|Bijan|'s Avatar
UCF Lexus
Shiit. Id rather have a stock ECU for now.
Sober....the "reset" screw on the ECU? Ive never used it like that, Ive always had the scanner.
Hopefully Jay is gona come by today, this **** is making me lose a lot of cheese.
Old Jan 31, 2006 | 07:19 AM
Kevlo911's Avatar
Kevlo for President
Check the fuse under the hood labeled ECCS(something like this) It is in the fusebox near the batt.
Old Jan 31, 2006 | 07:23 AM
|Bijan|'s Avatar
UCF Lexus
All fuses are good
Old Jan 31, 2006 | 04:45 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
If you need a ECU let me know a 95 ECU for now
Old Jan 31, 2006 | 08:50 PM
|Bijan|'s Avatar
UCF Lexus
I tried using another one, and nothing changed..
So Im assuming my ECU is good, and something else is still not right
Old Jan 31, 2006 | 09:04 PM
njmodi's Avatar
Not to state the obvious, but it seems like a harness or plug has been left disconnected or has broken/come undone from the connector.
Also - are you sure the OBD scanner hasn't gone belly-up - have to tried the ECU screw method or run to autozone to see if their scantool reports the same error?
Here is some info on how to test to see if the actual OBD (DLC) connector on your car is "live". Do these tests. If the pins don't test as stated below, then you just have a bad harness connection somewhere (since you already tried replacing the ECU).
Look at the check connecter (known as a DLC3 connector). There will be 2
rows of terminals/pins.
The bottom row (wide part of the DLC3) has terminals 1 through 8, counting
from the lower right to the lower left.
The top row (narrow part of the DLC3) has terminals 9 through 16, counter
from upper right to upper left.
Terminal #7 is the pulse generator during signal transmission - voltage will
be on-off.
Terminal #4 and #5 should always have less than 1 ohm of resistance between the terminal and body ground.
Terminal #16 should always have between 9 and 14 volts between the terminal and body ground.
Old Feb 1, 2006 | 04:43 AM
njmaxseltd's Avatar
Check the ECCS relay under the hood in the box in back of the left headlight.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
