Bi-Xenon RS6/TL HID Retrofits
Old Feb 10, 2006 | 09:45 PM
plate's Avatar
Has anyone done this yet on their 4th gen?
All I've come across are the E46 conversions. Not
really fond of those projectors. Curious to see how difficult it is
to mount the TL or RS6 projectors on stock max housings. Also
the wiring.. I'm aware you can use a relay/diode setup to keep
the low beams on while flashing hi-beams (to trigger bi-xenon solenoids)
but what about Maximas equipped with DRL?
Anyone?
Old Feb 10, 2006 | 10:00 PM
Tatanko's Avatar
Bacon Lover
Originally Posted by plate
Not
Why not?
Curious to see how difficult it is to mount the TL or RS6 projectors on stock max housings.
Not very easy. They are quite large and hard to fit in the housing.
Old Feb 11, 2006 | 08:02 AM
loverholic's Avatar
iAMIXAM!
if you ever get them done make sure you do a write-up
Old Feb 11, 2006 | 08:35 AM
plate's Avatar
Originally Posted by Tatanko
Why not?
Had a friend put one in his stock 98 max and I did not like the
beam cutoff.. Helped him modify the projectors with washers, shield bending.. no difference.. Still fairly fuzzy cutoff and little color at a distance. Yes, E46 beam pattern is nice and bright but if I'm going into the trouble of doing a retrofit I want something better.
Valeos are also a nice alternative but have not seen many bi-xenons floating around.
I'm planning on doing my retrofit soon so yeah.. I will try to take pics and do a write up.
Old Feb 11, 2006 | 09:03 AM
Tatanko's Avatar
Bacon Lover
My cutoff is extremely sharp and has all kinds of color to it
Old Feb 11, 2006 | 10:20 AM
nupe500's Avatar
Jedi Knight
why not look for E55 projectors...? I've got those in my headlights.
Old Feb 11, 2006 | 10:48 AM
Kevlo911's Avatar
Kevlo for President
I have the wire diagram for the TL Bixenons, I forgot to add to the Howto's
Old Feb 11, 2006 | 02:42 PM
nismos14's Avatar
§è~® f®ÈÄk
I wish I had the money to do this lol.
Old Dec 4, 2006 | 06:38 AM
miserov's Avatar
From: You can't spell 'Wisconsin is insanely boring" without "Wisconsin."
So has anyone put TL projectors into a stock 97-99 housing?
Old Dec 4, 2006 | 11:58 AM
f550maranello2's Avatar
yea me.........
Old Dec 4, 2006 | 12:26 PM
miserov's Avatar
Ok then, I just wanted to make sure i wasn't embarking on a futile task since I've only found people talking about retroing them, nobody actually saying that they have done it.
Old Dec 4, 2006 | 07:57 PM
maxgtr2000's Avatar
KH3 by popular demand
F550 has them also JSMexUSA was the first person I had seen with them on a max. I believe if you search hidplanet for his name you may find his install pics. To put it lightly when I saw the pics I was intimindated about doing tls in a max but it can be done. Also TL in cefiros are about to be done by Wed.
TLs to me are the hardest cause of the solenoid, and there is quite a bit of cutting, but if you can do those, you can do almost any other projector in a max.
I notice people are picky about lighting, I'm only running e55 singles but even those are way better than stock. e46, tsx, tl, rs6, they all are way better than what I'm running and I'm attached to my lights.
Old Dec 4, 2006 | 10:17 PM
alright hold on ill post some pics....
Old Dec 7, 2006 | 12:21 PM
miserov's Avatar
Thanks, that's what I was looking for.
Old Dec 7, 2006 | 01:12 PM
glenmoormax's Avatar
10 psi
maxgtr2000 is building my RS6 headlights now
Old May 4, 2007 | 09:39 AM
maxprivate's Avatar
Black Lion
curious what did you use as a shroud? and also wondering if you went the jb weld to seal up the housing.
Old May 4, 2007 | 11:47 AM
Sthmem's Avatar
I am running A6's right now. They are only single xenon though. Plenty for me. I never use the highs anyway.
Old May 4, 2007 | 02:41 PM
no i didnt use any jb weld cuz its crap.. dont be ghetto when do headlights.. ihave them bolted to the bottom of the reflector and im using about 5 layers of aluminum foil to cover up the back, then i coated the entire backing of the projector with clear silicone....
as far as the shroud, its a toilet bowl flange that i found at ACE hardware.. its the only thing that will fit..
Old May 4, 2007 | 04:29 PM
maxprivate's Avatar
Black Lion
wow you used silicone? that must have been a mess. do you have the tl projectors? as for sealing the projector im going to use foil tape and then figure what kid of sealer to use. why do you say JB weld is crap? this is what most people are doing to seal the projectors.
Old May 4, 2007 | 07:17 PM
maxgtr2000's Avatar
Jb weld is a waste of time and money imo for sealing, you will have to use alot depending on the gap between the projector and the back of the light, silicone is cheap and does the trick and God forbid you have to remove the projector for any reason after it dries, it won't be happening without a jackhammer if you use jb weld.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
